Case Mod - In Progress Category 5 Cyclone - C5C
Discussion in 'Project Logs' started by masbuskado, 1 Feb 2009.
  1. masbuskado
    masbuskado Compulsive Modder
    15 Sep 2008
    I start this project in 2008 a couple of months after I finish my AirSupreme I and this one was the sequel AirSupreme II but as you may know my "AirSupreme I" evolve so I let this project out of the picture, but know I rename the project and I'll take over once again... so the concept is the same as AirSupreme I or EvO but with 120mm fans... new light color scheme, some custom modification and more air flowing...
    Also this will be my first Inter-Forum thread meaning that this thread will be post in any Forum am subscribe. So it will be update simultaneously in all of the forums.
    As always there is no plan cuz whatever came to my mind I'll try to do it...
    So feel free to give your opinion, comment or disagreement cuz we know can't like to everybody...
    So let's the mod begin...
    Sponsored by:
    newmodcity.com (2x 140mm Fans, 2x 140mm Custom Fan Grills and 3x 120mm Custom Fan Grills)
    OKGear.com (4x 120mm Hex Mesh)
  2. masbuskado
    15 Sep 2008
  3. masbuskado
    15 Sep 2008
    The Case
  4. masbuskado
    15 Sep 2008
    Fiber Glass and Bondo
  5. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Looks good so far.Good luck.
  6. HaSLeS
    HaSLeS The Observer
    12 Jul 2008
    The top of the case looks pretty bad, but nice work so far. Good luck!
  7. SkyLord77
    SkyLord77 Use your teeth not a Dremel
    21 Dec 2008
    He's going to clean that up. Working with Fiberglass and Bondo is a messy ordeal.
    I love the idea.
    I think this is going to look SWEET when finished!
  8. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    that front is gonna be wicked bamf!
    great ideaa d00d! :)
  9. masbuskado
    15 Sep 2008
    Cutting
  10. masbuskado
    15 Sep 2008
    C5C (Category 5 Cyclone) Feb 05,2009
    Blow Holes...
  11. masbuskado
    15 Sep 2008
    C5C (Category 5 Cyclone) Video #1
  12. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
    wow, great start Mabuskado, i'm loving your videos! :thumb:
  13. masbuskado
    15 Sep 2008
    thanks man... part 2 coming soon... :D
  14. masbuskado
    15 Sep 2008
    Category 2 - C5C
    C5C (Category 5 Cyclone) Feb 13,2009
    Sanding...
  15. masbuskado
    15 Sep 2008
    The Storm Cage by masbuskado
    The Main Idea is... to put a real storm inside the case... yes a real storm...
    So I need the 3 basic components for that...
    1. Wind: Strong winds... For this I'll need 2x powerful 140mm Case Fan. Don't worry about loudness... Looking something around 120 CFM (already see all newegg fans - budget $30)
    2. Water: Heavy Rain... For this I'll need some kind of tiny sprinkler to create some shower effect (1/4" or 1/2" will be good).
    3. Lightning: Massive Thunder... I was looking for some flashing blinking disco light tiny enough to fit into the build (already founded see pics).
    All the components will be added into The Storm Cage I'll make out of acrylic...
    So basically right now I'll need some help finding the fans and the sprinkler just point me out where I can found them and thank you!!!
    I'll explain how this thing gonna work later...
  16. Supa_M
    Supa_M What's a Dremel?
    11 Jan 2009
    Storm in a computer case...crazy!..but i like it, can't wait to see how it turns out
  17. masbuskado
    15 Sep 2008
    yeah storm...!!!:rock:
    already made some test and will look awesome...
    Guys I need some help with the Fans and the sprinkler please read the Storm Cage post...!!!
  18. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    nice going so far... +3 for working with fiberglass and bondo alone, cant wait to see whats coming... good luck
    Subscribed!
  19. masbuskado
    15 Sep 2008
  20. Odin Eidolon
    7 Feb 2009
