Case Mod - In Progress Category 5 Cyclone - C5C
Discussion in 'Project Logs' started by masbuskado, 1 Feb 2009.
  1. masbuskado
    masbuskado Compulsive Modder
    15 Sep 2008
    Category 4 - C5C
    September 25, 2009
    Here are more pictures of the front...
    In this chapter we're going to disassemble the lightning machine to see how we are going to connect that to the PSU and move the controller to the front of the case.
  2. masbuskado
    15 Sep 2008
    Category 4 - C5C
    October 08, 2009
    The New Storm Controller
    3.5 Bay Old Fan Controller vs New 3.5 Bay Fan Controller
  3. masbuskado
    15 Sep 2008
    Video Updates
    The Storm Cage - Full Test Oct 11 - 2009
  4. masbuskado
    15 Sep 2008
    Category 4 - C5C
    October 14, 2009
    The Storm Cage ver. 2.0
    The first design was nice but it didn't let the air from the 2x 140mm fans go into the cage to create the chaos I was expecting so I decided to cut the front and add something I found at a local 0.99 cent store.
    My niece Modding with "Uncle Mas"
    Gluing a piece of acrylic to the front face to have more space for water!!!
    Casualty of Modding!!!
    So is 12:32pm here in NYC so I'll wait for the paint and the glue to dry!!!
  5. masbuskado
    15 Sep 2008
    Category 4 - C5C
    October 14, 2009
    New Mod City's New Water Block for socket 775, 1156 & 1366
    Testing the Storm Cage ver. 2.0
  6. masbuskado
    15 Sep 2008
    Category 4 - C5C
    October 15, 2009
    - Controlling Mother Nature
    - Temp Test
    Initial Temp 70F (Warm water was used to make this Test)
    15 Min (After): 68F
    30 Min (After): 67.5F
    45 Min (After): 67.1F
    Without any special setting or Hardware, just the The Storm Cage, the Pump and the NMC CPU Water Block.
    So now I'll explain how the Storm Cage Works...
    First it takes the water from the bottom of the Cage and distributes it through the loop... Then it hit the Rain Chamber where the water goes down as drops... then this drops are cool down by the strong winds from the 2x 140mm Fan in the front...
    So is like having Mother Nature inside a Computer Case. I can adjust the rain frequency and the wind velocity so I can control the Storm inside the Cage...
    Hopefully that make sense to all of you!!!
    stonedsurd likes this.
  7. Saikouguy
    Saikouguy Badass Unlocked
    13 Sep 2009
    So essentially the "Storm Cage" is just a added feature of a reservoir with the fans blowing into the water that is sprayed over back into the loop. I GEDDIT! :idea:
    Correct if I'm wrong
    Awesome job mate, seems like your work likes to revolve around water. :D
  8. masbuskado
    15 Sep 2008
    Yeap the "Storm Cage" works as the reservoir and as a Radiator...!!!
    Thanks man!!!
    This year all my mod are water cooled that's true but I luv air cooling too!!! :D
