Electronics Cathode questions
Discussion in 'Modding' started by mingingbollock, 26 Nov 2004.
  1. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    Hi all, couple of questions on cathodes and their inverters.
    Does anyone know what specs a normal 12" and 4" pc cathode inverter kicks out?
    I am looking to get Start.Voltage of 900vrms, Drive.Voltage of 400vrms and a driving current of 4-5marms.(tdk cxa-l10l) is recommended inverter but cheapest i have found in the uk is about £15delivered :jawdrop:
    Will a normal inverter do ? I opened one up but no specs and nothing to google.
    Also , does it matter which way the polarity is when driving a cathode ? sense says it will but i can't find a positve or negative on the cathodes in question-yes they are on lcds, yes i have checked the datasheets, no help there, and a search throws up few answers, but no definate yes or no.
    Please help, this is the last hurdle , then i get 2 Blue Gfx lcds to play with.
    Thanks in Advance :D
    Minging
  2. coorz
    coorz Miffed
    25 Apr 2003
    Sup mate, still toying around with dem LCD's ? :D. You can safely use those inverters (mine's from Sunbeam) from PC CCFL tubes for your LCD backlight. I've used them for 320x240 and even the 640x200 backlighting.
    There's no polarity on the output (CCFL) side.
  3. mingingbollock
    15 Mar 2004
    :D :D Thank You So Much :D :D
    I was going to sleep some now, think i will play with my toys instead lol
    240x128 and a Spanking new 320x240 :baby: lcd i received yesterday morning from Henry,
    and they are both blue, now do i mount em together or seperate ???
    Thanks again mate..
    Sleep who needs it :yawn:
  4. coorz
    coorz Miffed
    25 Apr 2003
    Ah the SHARP BSTN, i know what u mean :), very nice display if i may say so.
    How you mount it is up to you.
  5. mingingbollock
    15 Mar 2004
    Yes thats the one, :D addiction satisfied for a little while lol, very reasonably priced also,
    and it only took 4 days to get to UK from Finland, cheers Henry.
    Thanks again for the help mate, i will put some screens together this wkend,
    Just need those true type fonts again and my plan will be complete... for a while lol
