Modding Cathode Stealth and ideas...nice
Discussion in 'Modding' started by MiNiMaL_FuSS, 20 Mar 2004.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    -Unfortunately my host server is down, so no pics right now but i will add them.
    -This may get a lil hard to describe without the picture, but here we go.
    -In my case I have a pci slot support bar, that runs next to the pci slots straight up.
    -This bar is a 3-sided hollow peice of metal, that just so happened to be the exact height of my cold cathode.
    -So i stuck my cathode inside (stealthing my cathode) and it looks great.
    -However my cathode is Tri-Coloured (Red/Blue/Green from top to bottom)
    -Now these colour merge a bit and while still looking good they create a bit to much white light.
    -While experimenting i wraped a square tube of cardboard around the 3 side hollow bar that holds my cathode.
    -I can now choose to block anyone colour.
    -Currently i block the blue in the center and it looks truely amazing.
    -However i am slightly worried how hot the flat side of this cardboard will get, its basically touching my cathode...and i dont want any nice smokey special FX.
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    They produce very little heat, try rubbing your hands together, less than that.
    Or if you really wanna know, leave your pc on for two hrs or so, and pick the ccfl up, trust me, it wont be hot, maybe a bit warm.
    (defintly not enough to burn cardboard)
  3. Arien
    Arien What's a Dremel?
    22 Jun 2003
    Yeah it will be fine.. it's only the invertor that gets warm.
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Look forward to seeing some pictures, but if you can see the thing from outside the case_ "CARDBOARD" . Why not make up something from plexi or aluminum or something.
    Your buddy MS
  5. MiNiMaL_FuSS
    24 Dec 2003
    Plexi would eliminate the point of using it to block light m8 :p
    Besides i moved it to inside the metal support so u cant really c it unless ur looking for it.
    so all is good easy and cheap.
  6. modsquad
    27 Feb 2004
    Plexi does not have to be clear,but your are correct. If you can't see it from outside--
  7. MiNiMaL_FuSS
    24 Dec 2003
    yup....cardboard all the way!
    i mean cumon...i stelthed my drives using bluetak.
    I gotta be the cheapest modder on here :p
  8. Seth
    Seth What's a Dremel?
    14 Mar 2002
    cool idea, I want to see the pics when you get your host back up.
