Modding Cathode Throbber
Discussion in 'Article Discussion' started by macroman, 20 Apr 2002.
  1. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    Just sayin that for making those pcb's you can use PCB that has a light reactive side, print those schematics out onto a piece of over head projector film, stick on the side of the PCB, bung it under a light source for two mins and hey presto. Remove the OHP film and if you hold it under a light you can see a slight change on the surface colour. Give it a good wash so to remove the excess stuff and bung in your etching tank etc. When it comes out it should have removed all the un-needed copper leaving the tracks behind that you had drawn on yer pc etc in the first place.
    No need for pens and can create v precise tracking for making larger circuits not so large on pcb. Some programs like Crocodile Clips have a PCB creation part where you literally select the chips etc that you need, link all the stuff up visually by drag and drop, click "Make PCB" and then it works out the best routes for the tracks, then print straight off. Sure a lot of you know this but thought i'd add my bit.
    Oh and Macro, v nice article :D ...*emails head of the engineering lab asking use of etching tank*....
  2. macroman
    macroman The One
    3 Sep 2001
    I never mentioned UV pre-sensitised boards simply because anyone who has that kind of kit would know how to use it and what to do with the pics. The pens are for those peeps who don't have access to that sort of gear. ;)
    BTW glad you liked it - more to come ;)
  3. Slink
    Slink B7
    7 Oct 2001
    Thanks Macro, youve just give me multiple ideas
    great work:hehe:
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Same here, can't play in WMP7.1 (or 6) and can't even "Save Target". :cries: :cries: :cries:
  5. macroman
    macroman The One
    3 Sep 2001
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I'll have a look, it's off March PC-Answers (the Bit-Tech edition) :D
    I've got all the latest bits, and a downloaded wmv file plays fine :sigh:
    Later edit: And can play wmv online at other sites, so the player's working.
    Meblin - try testing one of these, small files http://www.matty-b.tv/video/jeep/
  7. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    Same here. Downloaded all the latest stuff but no joy :(
    Meblin
  8. i_h8clowns
    i_h8clowns <img src="http://www.bit-tech.net/ataraxia/it.gif"
    9 Sep 2001
    twinkling stars
    i just got my gf three of these star lamps from IKEA. basically it's a plastic star with a bracket which holds one standard lightbulb. is there a similar circuit i can make to plug these stars into so it gives them a twinkling effect? i'm in the US so i would be dealing with 110-120V AC and 25W lightbulbs. if anyone can help me out that would be awesome! it would look way better than just a plain lit stars on the wall. :lol:
    btw, awesome article there macroman!
    ...maybe i should post this in the Electronics forum but this mod gave me the idea :D
  9. Slink
    Slink B7
    7 Oct 2001
    Macro, why dont you wire a few of these up and knock them out on the for sale forum, im sure you would make a few 'bob selling to people like myself who dont have the patience to build a little circut like that,
    Just a thought
  10. Meblin
    5 Mar 2002
    How much would you be willing to pay?
    Parts would come to about £6 (including the molex connecters and board). I am going to give it a go at the weeked so will let you know how hard/easy it is. I thought I might put it in a little box with the adjustment wheels just poking out the side.
    Meblin
  11. Slink
    Slink B7
    7 Oct 2001
    email details in my sig,
    Drop me a email some time regarding it
  12. Lythe
    Lythe What's a Dremel?
    23 Apr 2002
  13. macroman
    macroman The One
    3 Sep 2001
    :D Welcome to the forums.
  14. M1CUZ
    M1CUZ What's a Dremel?
    5 Mar 2002
    Is the Tip3055 really needed, as a transistor rated at 15A seems a little excessive to me (and my wallet) however i do seem to have a large collection of tip50's laying around but these are only rated at 1A, just wondering if i could sub these in, or would they not be right for this job??
    Any thoughts welcomed!!
  15. TheBigE
    TheBigE What's a Dremel?
    20 Apr 2002
    Would this circuit support using two cold cathodes per output? If not what all would have to be upgraded, the transistors?
  16. macroman
    macroman The One
    3 Sep 2001
    I used the 3055's simply because they were to hand and I knew they were well up to the job. (What will do a lot will do a little ;) ). They do get slightly warm with continued use but nothing to be concerned about. I see no reason not to use the TIP50 or any other suitably rated transistor.
    In answer to the use of multiple cathodes, I haven't tried that but see no reason why it should not work. Bear in mind that different inverter/CCFL cominations may perform differently and so may not produce identical effects for a particular control setting. It is definately worth trying ;)
  17. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    More than likely. I think that if you went and bought a couple of power transistors, that that would work just fine.
    Signing out...
  18. M1CUZ
    5 Mar 2002
    Just been and measured the current consumption of one of my cold cathode inverters it draws about 400mA whilst running so depending on how many CC's you want to run pick a suitable transistor to match. So if you use the TIP3055 you should be able to run about 30 inverters, but i think your power supply would probably start smoking before the transistors would :worried:
  19. macroman
    macroman The One
    3 Sep 2001
    The transisor would need a HUGE heatsink and even then the 3055 couldn't handle that sort of power!:eeek:
  20. Rezostat
    Rezostat What's a Dremel?
    20 Apr 2002
    Hey Guys, I'm another newbie here, and I love all the stuff you guys are doing. Really inspirational and quite cool I must say, but I was wondering if you would tell me Macroman, what software do you use to draft your PCB schematics and parts layouts as shown in the guide? And I totally agree with you on the rub on transfers idea, resist pens are good too but find a good one or go over your design more than once just in case. Do you prefer Ferro Chloride etchant or Ammonium Phosphate?
Tags: Add Tags
