Caution: Wet Floor PC [prototype]
Discussion in 'Project Logs' started by GlassX, 23 Jan 2005.
  1. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    Home Depot Sells it for cheap :D
  2. x3x3non
    x3x3non What's a Dremel?
    9 Feb 2004
    usplastics.com has plenty of weld on, buy the smallest container you can though. I ordered the 1 pint can, and i think i could glue the whole empire state building with it. Seriously, every joint takes a couple of drops.
  3. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    use ducttape to top the psu from swinging?
  4. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    pretty cool :rock:
  5. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    you want to be careful, when you mount the psu make sure to have extra supports so that if the mounts on the side fall off it will not go crashing onto the mobo!
  6. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Did you key the surface before adding the glue? - you know, rough it up with sandpaper.
    - H.
  7. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
    Try to attach your PSU like ZapWizard did. (see thread http://forums.bit-tech.net/showpost.php?p=372067&postcount=300 )
    Hope that will work for you. :confused:
    Keep up the good work! :thumb: :thumb:
  8. GlassX
    GlassX What's a Dremel?
    11 Jul 2004
    Not in Canada :-( They havnt even heard of the stuff. And the shitty thing is that if I wanna order it online, its got to be shipped ground. Option 1: USPS. 8-10 weeks. Option 2: UPS. Customs rape.
    However, I discovered the sign is made out of "PP" (5) Polypropelyne or something. Which, is the plastic used when nothing is supposed to stick to it.
    Will do. 4 brackets, each with 4 wood screws, held into a plate with a square foot of contact area with the sign. That, and thick plexiglass. (The thin stuff I was using shattered on the "drop test".
    Tried.. everything from 30 grit all the way to 600 grit.
    Unfortunately, my 10 year old table saw is in the garage, its -20c outside and wont quit snowing. Theres a nice, big, pile of snow between the front of the garage and the front door of the house.. So bringing the table saw inside is out of the question for now. It'll clear up in a day or two... However, I started another project outside involving snow. Pics, soon :)
    Thanks everyone!
  9. MenloR
    MenloR What's a Dremel?
    31 Dec 2004
    nice idea dude :jawdrop:
  10. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Héhé
    that reminds me of the movie "the terminal".
    :D
    Good luck with the project
    looking good
    L
  11. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    is the wet floor sign incase your water cooling spills everywhere?
    :hehe: oh the irony if someone tripped over it and broke your pc hehe :hip:
  12. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    nice idea i like this one. about the PP go to a plexi store and and ask them about PP glue. i dont know how is it in canada but here can u get glue for every sort of plastic. or buy a plastic welder. they cost about 30euro/35usd dont know whats that in canadian dollar.
    keep on modding
  13. GlassX
    11 Jul 2004
    Hoestly, I've never heard of that. But if its only 35usd (40cad) Ill definately look into getting one.
  14. Axly
    Axly slo-mo...dder
    7 Nov 2003
    Try looking for PL400 glue... that sticks to frigging everything
  15. antiHero
    19 Jan 2005
  16. Jrose152
    Jrose152 What's a Dremel?
    23 Jan 2005
    one of the most unique mods ive ever seen...
  17. GlassX
    11 Jul 2004
    Time for an update, no?
    I'm writing this at 6am from a lan party, because I cant sleep thanks to this guys 120000000dba fan. *sigh*
    So, this is where the "prototype" part of the project branches off. The sign itself and the wood are not the final peices, the plexi is. It's just to make sure it's all going to work.
    Now.. my photo host is down.. So I'll upload some progress pics soon.
    Im entering my case into the case mod competition tomorrow, hope I win. (Lian-Li p60)
    'night
  18. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Sweet design. I love original ideas. I would definitely try melting the plastic (either chemically or with heat) to stick stuff to it. Any plastics store should be able to help.
    Keep up the good work. I love it!!
  19. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    hehe cool idea. Never seen this one before:) Be cool how it ends out. When I think about it you could do some real cool modding on it
    - S
  20. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    hahah great idea!
