Electronics CCFL Switch
Discussion in 'Modding' started by Clanure, 4 Nov 2004.
  1. Clanure
    Clanure What's a Dremel?
    30 Sep 2004
    Okay,
    I bought a new switch to handle my 3 dual cathode CCFL's and now I am wondering if the switch will handle all 3. Is there any problem running the 3 CCFL's all to a single switch? I'm not going to try anything fancy, just replace the expansion slot switches (3 of them) with a single switch in front.
    Here's a pic
    Will this work?
    Do I need more than one switch?
    Thanks,
    Clanure
  2. Clanure
    30 Sep 2004
    Anybody?
    Also, does anybody know of any good resources (books, hands-on) to learn basic electronics? I've read some of the tutorials online, but I am much better with hands-on tangible learning. If anybody could point me in the right direction, I would appreciate it.
    Then I might not need to bother you all so much.
    Thanks,
    Clanure
  3. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    1 switch will do you just fine. As for learning electronics - there is a sticky about that which has many good resources.
  4. Clanure
    30 Sep 2004
    Found it. Thanks for the help.
    Clanure
