CD-Rom Drive Problems
Discussion in 'Hardware' started by Lazy, 5 Jul 2002.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    i just finished building a friends computer but the cd drive won't recognise some cd's. It is a Samsung 52 x CDROM Drive Oem. Most cd's worked fine but on 2 driver discs it said the data was corrupted or an unknown format and wouldn't access them.
    I just tried them on my pc and they work fine. The pc is running win xp pro.
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    You could try a different IDE cable.
  3. herbs
    herbs Nobody but us chickens
    7 May 2001
    Nope its the crappy samsung, it spins too fast, try using nero speed i think its called to slow down the cd.
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    okay cheers, where can i get nero speed from?
  5. dukebox_1st
    dukebox_1st What's a Dremel?
    26 Apr 2002
    AFAIK drivespeed is only availiable with nero burning rom. i have the excat same drive but don't have ne problems with it, infact i think its great, fast, queit and cheap!
    tom
  6. herbs
    7 May 2001
  7. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    i got that cdrom and havent had any problems with it...
    i found it to be less of a problem then the equivilant LG drive which does spin the cd up too much....
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    i will try it when i next go round his house. Cheers for the help. :)
