Windows CD ROM not being recognised
Discussion in 'Software' started by j_whyte, 14 Sep 2011.
  1. j_whyte
    j_whyte What's a Dremel?
    2 Mar 2011
    Hi,
    For a while now my pc has been requesting me to insert the windows vista installation disk and perform a repair; about every 2 or 3 days.
    Although an inconvenience, I could usually complete the repair in under 10 minutes and have vista loaded.
    Here's where the problem is....
    The pc boots and requests a repair but my DVD-ROM and DVD-RW drives won't open and the led's won't flash meaning i can't get past the page asking me to insert a repair disk.
    The cd drives open and close and flash when connected to the power only, but as soon as i connect them to the motherboard they become lifeless.
    Any help much appreciated.
    motherboard- asus p5q
    cpu - Intel E8400
    RAM - Corsair Dominator pc8500 DDR2 1GBx2
    VISTA 64bit
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Tried other ports on the mobo?
  3. j_whyte
    2 Mar 2011
    The drives can only be attached by a single port on the motherboard.
  4. GoodBytes
    20 Jan 2007
    I think you simply forgot to attach the power cable to your DVD drive.
    Check for that. And if you have a modular PSU, check if the power cable is well inserted on the power supply unit itself.
    Else it's broken, and need to be replaced.
  5. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    If you only have one socket I assume it's IDE. Do the drives open when the PC is posting? Two things to try. Firstly make sure your jumper settings are correct (master/slave or cable select) and try a new IDE cable as yours may be damaged. Also try operating only one drive at the same time (again making sure you have the jumpers set as master). In addition, IDE is enabled in the BIOS?
  6. GoodBytes
    20 Jan 2007
    Even without an IDE/SATA Cable the optical drive opens/close when you press the eject button.
  7. MrWillyWonka
    25 Jul 2004
    True, but with a faulty cable (or other problems) the firmware may override an eject request. It's rather unlikely that two drives would fail to respond so I suspect it's a IDE cable or controller issue.
  8. GoodBytes
    20 Jan 2007
    Very true.
    But I was thinking more or a power cable feeding both drive.
  9. MrWillyWonka
    25 Jul 2004
    Sorry should have been more clear on the type of cable, have edited my original post!
  10. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    You'll either have to boot from a USB stick or another hard disk (with a Windows install prepared using another system).
    However the big question IMHO is why your system was requesting a repair install every few days. I would be strongly inclined to suspect malware at work (in particular, something tinkering with your boot sector or even the BIOS since it seems to be surviving a repair) and would suggest you either try a fresh Windows install from USB, or take the hard disk out and check it for malware using another PC.
  11. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    +1 to that, I had my system not even detecting the DVD drives after POST. I used an external USB DVD drive for the reinstall rather than USB stick though, it may be worth seeing if you can borrow one from someone first to get the repair done. If you can get the system to boot I'd strongly recommend backing up your data to another drive then doing a nuke and pave - it's the only way to be sure.
    If you can't get the system to boot then it may be the BIOS, as AstralWanderer has suggested. Fortunately you can flash the BIOS on the P5Q series from a USB stick. That's another option should it turn out to be BIOS related rather than the OS.
  12. AstralWanderer
    17 Apr 2009
    This would probably be a better idea since a (read-only) CD/DVD can't be subsequently infected by malware. Alternatively, an SD card (with the write-protect slider set, once you have copied the appropriate data onto it) in a USB adaptor should do the trick too.
