CD-RW not workin :(
Discussion in 'Hardware' started by j03, 2 May 2002.
  1. j03
    j03 What's a Dremel?
    14 Mar 2002
    I over clocked my cpu earlyer and it wouldnt start up so i had to reset the cmos. When i got back up i realised my cd drive dont work :( but the activity lights on all the time ? do i need to insttall drivers somewhere or summut ?
  2. GJUK
    GJUK What's a Dremel?
    10 Apr 2002
    could we have a few more details ?
    did u o/c by the fsb ?
    and by how much if you did...?
    fsb effect all hardware, and if youve gon too far...boom :( cd writer as wel...although cd writers crappin out are relitivly rare...
    make sure however that in your bios all setting are correct as you reset it.
    also that all leads are in:)
    Jono
  3. j03
    14 Mar 2002
    well i overclocked it to 140 fsb (from 133) and it crashed going in to windows so i reset went back into bios and set it back to 133 then when i exited the pc would power up but nothing would show on monitor. Thats when i reset cmos, so i got back on but now it doesnt detect a CD drive :(
  4. Adam
    Adam Minimodder
    26 Jan 2002
    If the drive doesnt appear in My Computer then probably the configuration for the IDE bus has been changed by resetting CMOS. Try deleting the IDE controllers from device manager then rebooting.
  5. j03
    14 Mar 2002
    ok thx for that :) ill give it a shot.
  6. GJUK
    10 Apr 2002
    140 fsb is fine man, try the above ^...gd advice.
  7. j03
    14 Mar 2002
    ok i didnt need to do that. Im going to sound like an idiot now, I had the IDE cables in the wrong sockets I just switched them arround and w00t :) i dunno how it was working earlyer? I cant run any faster than 138fsb somthing doesnt like it any faster ?? i think it might be my sound card its only a sound blaster 128 ?:sigh:
  8. GJUK
    10 Apr 2002
    usually summin simple :)
    ull find its ur cpu mate...maxed, if ur not uppin the v's ;)
  9. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    or your temps causin ur system to crash...
  10. GJUK
    10 Apr 2002
    yeh. wot are your temps ? if there over 50ish then ur TOO HOT imho
    Jono
  11. j03
    14 Mar 2002
    my temps are about 45'C but ive just got a new Heat sinc (akasa silver mountain 2) but i forgot to buy a shim so i cant put it on till i buy one :( oh and i reach 49'C at full load
  12. felix the cat
    11 Jan 2002
    thats a bit high...so that will probable be partially why ur pc crashes....
