Disaster cds dont like spinning fast.
Discussion in 'Modding' started by modz-a-lot, 3 Jun 2004.
  1. modz-a-lot
    modz-a-lot What's a Dremel?
    28 May 2004
    well, a few days ago, my friend told me about a episode of mythbusters where they tried to figure out if a cd could really shatter inside a cd drive. too bad, i missed the episode :duh: well, being the clever kid that i am, i decided to test it out. i first hooked up the cd spinner thingy from an old cd drive to a small fan motor. nope, cd intact. not even close to breaking. wanting to get a little more speed, i hooked up the spinner thing to a 4 hp vacuum motor. well, i ran an extension cord out of the room, not wanting to get hurt, and plugged it into an outlet. i could hear it spinning up. so i left it in. after 5 seconds, i thought it was at max speed. 5 more seconds later, i started hearing this high pitched squealing sound, then 2 seconds after that "BOOM!" it scared the CRAP out of me. below you can see what happened
    the remains of the cd, and the motor sitting in the clamp
    here you can see that exploded cd shards ripped through a paper target on the wall
    cd sharts projected into the door
    uh oh, my parents are going to flip a ****. broken glass on the picture frame!!! notice the red piece of cd projected into the pegboard.
    more evidence of flying cd pieces
    the remains of the cd (or at least the ones that i picked up...they were scattered as far as 20ft. away!)
    in conclusion, a cd will not break under normal conditions, unless it is precracked or badly warped. do not try this unless your outside, or if you dont care about pictures, walls, doors, or in my case, the electronic studfinder that took most of the force. the whole side of it was blasted off! i'll try to get a pic of that later
  2. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Wild, I love it :rock:
    Cheers,
    Mike
  3. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    hope you dont get a huge spankin from ya parants :rolleyes:
  4. Geektechnica
    Geektechnica Minimodder
    11 May 2004
    I too have done this. Except I wedged the cd onto a sanding wheel for my dremel. Got it up to about 30,000RPM before it exploded. Shards of the CD embedded them selves almost 1" into the drywall and ceiling. Not to mention poking up through the carpet. I have pictures of the aftermath, after I find them I'll post them.
  5. EdHunTer
    EdHunTer What's a Dremel?
    8 Apr 2004
    :eeek: scary
    well i'm sure as hell i won't ever try this one inside the house :D
  6. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    I so have to do this. We should start a competition, see who can get cd shards the deepest into different materials. Rock on man!! :rock:
  7. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Different materials, like in yourself? :hehe:
  8. kiljoi
    13 Oct 2003
    Only if you volunteer too! :D
  9. Prophet
    Prophet Minimodder
    19 May 2003
    Frisbee CDs are fun too, Specially if you get some speed and nice straight on crash with a wall, watch them explode on impact :)
    Proph.
    Edit > And if your after more fun things to dow tih CDs, microwaves are great. High power, not to long, watch the sparks and then check out the pretty patter. I made a lil collage on my wall once of a whole load i did, Never come out the same and look pretty with light reflecting off them :)
  10. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    *pulls old 52x Cd drive and batteries from under bed*
    right i'm off.if i don't report back in a bit i'm dead or asleep
  11. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I think the trick is to mount them vertically rather than horizontally. But Im not crazy enough to try this :D
  12. star882
    star882 What's a Dremel?
    19 Mar 2003
    I had once witnessed a CD exploding in a drive, it turns out that the PLL in the drive failed so the motor just revved up as fast as it can go.
    All the pieces were contained in the drive.
  13. modz-a-lot
    28 May 2004
    i find it hard to believe that any motor the size of a typal cd-drive motor can spin a cd fast enough to shatter it. when a cd truely shatters because of speed, its because of the outward pull (centripetal force) of the cd on itself. i think for a cd to shatter in a cd drive, it would have to be precracked or badly warped/off balance. i'm going to do this more outside, the exploding noise is soooo cool!
    by the way, the cd kept spinning on the thing so i cheated by using some super glue, if anything, this just helped it spin faster before it exploded. just a warning, if these things can get projected through pegboard, and pushed .5 inches into solid wood, they will easily break skin. do not be closer than 40 feet when doing this (being in another room is even better) good luck!
  14. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    very stupid idea for me i treid that with my dremel and lets just say it ****ing hurt when it wnet into my arm oh well thats what you get for being as dumb as me and it will heel soon i hope
  15. ratty
    ratty What's a Dremel?
    4 Nov 2003
    u've found something to do with all the aol cd's :D
  16. Geektechnica
    11 May 2004
  17. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    did u guys hear about the guys who collected about 15000 aol CD's and sent them back one at a time in different sized envelopes lol it was funny as hell
  18. Carbon
    Carbon Banned
    8 Jan 2003
    lmao! serves AOL right!
  19. lcdguy
    lcdguy Minimodder
    25 May 2004
    somone should take a high rpm motor, like the ones out of vacums, or dustbuster, then gear it to go faster.
    Or perhaps, hook it up to a gas or nitro fuel engine
    if someone has access to liquid nitrogen, freeze a hd platter and see if it will explode from centrifical force.
  20. sinizterguy
    25 Jul 2002
    That guy must have spent a fortune on postage.
