Electronics Cell phone modding
Discussion in 'Modding' started by Isuo, 12 Jul 2007.
  1. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Ok, what I'm planning to do is leave my cell phone battery and start using normal batteries instead. My problem is, however the middle pin (SE J100i).
    I mean the pin which shows the charge of the battery.
    So the thing goes, what do I have to connect in that pin to make the phone show the charge of any given battery?
    I got an answer to this from a cell phone forum, and apparently the cell phone batteris have the feature built in them, but I don't really trust them too much. Would there be a way to hack the battery open and connect a couple of wires or something?
    The second thing is, that If I bought one of those battery charge status showing gizmos, do they drain energy in the long run?
    PS; looks like the forums have changed once again and I don't like them one bit...
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    You're saying you want your phone to run on AA batteries? o_O
    What kind of phone is it? I have a phone which runs on AA rechargeable batteries but it's got a European charger, granted, the batteries are encased, and it doesn't even last a day on full charge, much less if I make calls :p
  3. Isuo
    13 Oct 2004
    Exactly!
    It's the SonyEricsson j100i, small basic phone (nomp3, camera, radio...). It has got a 900mAh battery, but I don't like it too much.
    The thing why I want to make it, is to keep the phone going for a year with one charge. If that means a garage full of car batteries, then so be it.
    Well, maybe not for a year, but anyways longer than a week...
  4. const_
    const_ What's a Dremel?
    15 Nov 2005
    from what i understand is you got some kind of project that require a phone battery lasting very very long time and not planing to make it portable.
    try thinking green ! how about solar panels? giant ones. wouldn't that be cool ?? a phone with a fat cluster of batteries and a big solar panel that recharges it.
    battery charge = infinity, no need for any circuitry to show battery status
    just an idea though
  5. Isuo
    13 Oct 2004
    Hmmhmm, solar panels would be nice, but I don't know any decent priced shops from where I could buy them (I live in Europe).
  6. jakenbake
    jakenbake full duplex
    5 Jun 2005
    ya, if you have the money. they cost a fortune for not-so-great efficiency.
  7. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    use a kinetic energy device that as you walk, recharges it.
  8. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    If you don't need it to be portable, why don't you just keep it connected to the charger?
    Would probably be easier to get a 12V car charger and hook that up to 12V batteries.
  9. Krikkit
    21 Jan 2003
    The only problem with trying to run it on batteries is that the normal battery usually gives out an unusual, consistant voltage to the phone (afaik) - whereas AA batteries vary their voltage dependant on their charge.
  10. Isuo
    13 Oct 2004
    Using a car battery would robably be the easiest way. I suppose a car battery would last a long time, but does anyone know the mAh- thing of a car battery?
    e: Korad: Do you know any proper electorincs shops in Holland or Belgium?
  11. Koradhil
    9 Nov 2004
  12. Isuo
    13 Oct 2004
    Excellent, thank you!
