Other Cell Phone Ringtones
Discussion in 'General' started by Sparrowhawk, 21 Sep 2009.
  1. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Anyone know a good way of sending/converting/etc a MP3 to be used as a cell phone ringtone? :sigh:
  2. pennyman86
    pennyman86 New Member
    18 Jul 2009
    http://mobile17.com/
    you upload the song and tell what time in the song you want your ring tone.
    and then they send it to you
    mvagusta likes this.
  3. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    I use garageband on mac for my ringtone needs... but I have an iPhone, and live in the uk so it's my only option really..
  4. October
    October Mariachi Style
    20 Jul 2009
    Get a phone that can play mp3s, keeps things simple :D Even ridiculously cheap phones can play them these days.
  5. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    For what phone? most will use MP3's (except the iphone, but there is a work-a-round)
    for my iphone I use iTunes to create a file of the right length
    Set the import properties of iTunes to AAC.
    Select the track you want to create a ringtone of and make a note of the start and end time of the section you want to use as a ringtone (30 seconds max).
    Go to "Get Info" in the context menu and select options.
    Change the Start & End time to the Start/End time of the section you want to use.
    Close the properties menu and select create AAC version from the tracks context menu.
    You should now have a new track where the time is <30 seconds long (you can now reset the start/end time in the original track).
    Drag the new track to the desktop (or a folder if your going to keep a backup copy your new ringones) and enable viewing file extensions in the explorer window options.
    Change the file name extension from .m4a to .m4r.
    Open the Ringtone tab in iTunes and drag & drop the renamed file in to the window.
    Re-sync and you should have your new ringtone.
    bit long winded but it works.
  6. Rkiver
    Rkiver Cybernetic Spine
    23 Apr 2009
    Depending on the phone and what it wants I use Audacity.
  7. knuck
    knuck Hate your face
    25 Jan 2002
    the phone might but the provider might decide you won't be able to use it... I can't do this with my LG Rumour, thanks Bell Canada !
  8. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I find Audiko.net works well. Even grabs sound from Youtube videos.
