Linux CENTOS - XINETD
Discussion in 'Software' started by deathtaker27, 19 Feb 2013.
  1. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Hi,
    After some more Linux advice (I will probs be posting 1 a week after my lectures as Linux is confusing me a lot tbh, so bare with me and thank you all so much for the help!)
    I need to configure xinetd, from my understanding you configure each service as a new file within the directory /etc/xinetd.d/
    I have configured one for ftp, following the example given for telnet (both below) and have changed the configuration on echo-stream (also below) and restarted the service, but service is still failing to work, could I get some pointers in what I have mis-configured
    Echo-Stream:
    Code:
    # This is the configuration for the tcp/stream echo service.
    service echo
    # This is for quick on or off of the service
    #Only thing edited in this file
            disable         = no
    # The next attributes are mandatory for all services
            id              = echo-stream
            type            = INTERNAL
            wait            = no
            socket_type     = stream
    #    protocol        =  socket type is usually enough
    # External services must fill out the following
    #    user            =
    #    group           =
    #    server          =
    #    server_args     =
    # External services not listed in /etc/services must fill out the next one
    #    port            =
    # RPC based services must fill out these
    #    rpc_version     =
    #    rpc_number    =
    # Logging options
    #    log_type        =
    #    log_on_success  =
    #    log_on_failure  =
    # Networking options
    #    flags           =
    #    bind            =
    #    redirect        =
    #    v6only          =
    # Access restrictions
    #    only_from    =
    #    no_access    =
    #    access_times    =
    #    cps             = 50 10
    #    instances    = UNLIMITED
    #    per_source    = UNLIMITED
    #    max_load        = 0
    #    deny_time    = 120
    #    mdns            = yes
    # Environmental options
    #    env             =
    #    passenv         =
    #    nice            = 0
    #    umask           = 022
    #    groups          = yes
    #    rlimit_as    =
    #    rlimit_cpu    =
    #    rlimit_data     =
    #    rlimit_rss    =
    #    rlimit_stack    =
    # Banner options. (Banners aren't normally used)
    #    banner          =
    #    banner_success  =
    #    banner_fail     =
    Telnet:
    Code:
      GNU nano 2.0.9               File: telnet
    # default: on
    # description: The telnet server serves telnet sessions; it uses \
    #    unencrypted username/password pairs for authentication.
    service telnet
            flags           = REUSE
            wait            = no
            user            = root
            server          = /usr/sbin/in.telnetd
            log_on_failure  += USERID
            disable         = no
    VSFTPD:
    Code:
      GNU nano 2.0.9               File: vsftpd
    # default: on
    service vsftpd
            flags           = REUSE
            wait            = no
            user            = root
            server          = /usr/sbin/vsftpd
            disable         = no
    Thank you all soo much for your help
    And yes I know telnet is insecure but what uni wants it will get
    DT.
  2. faugusztin
    11 Aug 2008
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I have been told to use ftp and telnet through this, im very much a linux noob :(
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    in the past when I have had xinetd configured correctly, I have not been able to work until I have done the following:
    killall -SIGHUP xinetd
    service xinetd restart
    my service file looks like:
    Code:
    service livestatus
    	type		= UNLISTED
    	port		= 6557
    	protocol	= tcp
    	wait		= no
    	cps		= 100 3
    	instances	= 500
    	per_source	= 250
    	flags		= NODELAY
    	user		= icinga
    	server		= /usr/bin/unixcat
    	server_args	= /usr/local/icinga/var/rw/live
    #below configure the IP address of the central icinga server
    	only_from	= ****IP OF CENTRAL SERVER****
    	disable		= no
    (my file is from a debian build though not redhat/centos)
    Are you not needing to specify a port at all?
    deathtaker27 likes this.
