Scratch Build – In Progress CERBERO warboy - 99% completed
Discussion in 'Project Logs' started by warboy, 4 Aug 2015.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^I'm guessing that's pinstripe masking tape for the paint job.
  2. warboy
    warboy Insane modder
    24 Nov 2011
    yes, orange is the tape for masking...
  3. warboy
    24 Nov 2011
  4. warboy
    24 Nov 2011
    Finally the componets are:
    Motherboard: MSI Z97A GAMING 6
    Graphics Card:MSI GTX 980 GAMING 4G
    Chassis: CERBERO --> https://www.facebook.com/cerberowarboy
    Ram: 16 Gg AVEXIR Blitz1.1 Series - DDR3 (4x4Gb)
    Power supply: Bitfenix Fury 650G
    Fans: 6 x Bitfenix Spectre Pro LED white
    LED: Alchemy 2.0 Magnetics Led Strips
    CPU: Intel i7 4790k
    Fan Controller: LAMPTRON CW611 xtremehardware.com edition
    SSD: Samsung PRO 128 GB
    HDD: 4 TB WD Green (2 x 2Tb)
    Liquid cooling:
    EK XRES 100 D5 vario
    Alphacool NexXxoS XP³ Light - Acetal Edition
    Alphacool NexXxoS ST30 Full Copper 360mm
    Thanks to Bitfenix and AVEXIR For the support!! :clap::clap::clap::clap::clap::clap:
    [​IMG] [​IMG]
  5. warboy
    24 Nov 2011
    The LED: Alchemy 2.0 Magnetics Led Strips
    The ram 16 Gb AVEXIR Blitz1.1 Series - DDR3 (4x4Gb)
  6. warboy
    24 Nov 2011
    and now New look with the chamaleon effect on MSI Z97A GAMING 6
    Masking
    and the result:
    but with the direct light the colors change
  7. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Dude upload your pictures somewhere and have them resize them before you post them.
  8. BLAMM0
    BLAMM0 What's a Dremel?
    28 Jul 2014
    Nice hands you have there :D
  9. The Colonel
    The Colonel What's a Dremel?
    18 Jul 2014
    Fantastic Bro!
    I'm waiting to see what you are creating this time (y)
    Unique MoBo :eek:
  10. Cheapskate
    13 May 2007
    The board looks kinda fruity, but still awesome.:D I didn't know you could get away with that. I always figured the glitter was conductive.
  11. warboy
    24 Nov 2011
    thanks guys!!!!
    It does not conduct, because it is plastic fragments inside the plastidip
  12. warboy
    24 Nov 2011
    and now I mount the hardware on CERBERO...
  13. warboy
    24 Nov 2011
    the final pictures but soon will install the rigid tube....
  14. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    You've got lovely manicured nails :D:D
    Build looks A1 also :thumb:
  15. warboy
    24 Nov 2011
    I'm happy for the result to MSI PRO MOD SEASON 2
  16. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    Congratz for 2nd Place
    Nice build but is it finished yet ?
    Placement of the LED strips by the radiator looks like you had to put them on to show it off, but it looks totally out of place. The White strips would have looked better on the inside as the green ones don´t match anything.
    The Paintjob on the frame is outstanding with love for details, but then tubing to and from the radiator looks like a 3 second time job. It would be totally awsome if the tubing to the radiator would run inside the Framerails.
  17. Cheapskate
    13 May 2007
    Congratulations.:D
    Pics are awesome. I like the splice job on the leds. nice and clean. Paint came out awesome. I'm guessing the tubing was rushed a bit due to the deadline.
  18. warboy
    24 Nov 2011
    Thanks guys!
    Soon with rigid tubes
