Features CES 2019 Roundup - PC Hardware Highlights!
Discussion in 'Article Discussion' started by bit-tech, 10 Jan 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    What's the slot on the Asus motherboard that looks like a DIMM slot but is keyed wrong?
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    This:
    They have it on their Dominus Extreme and the other two boards shown in the article.
  4. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    On the Matrix 2080 Ti:
    Wow, that's actually really awesome and pretty innovative... You have surprised me Asus.
  5. perplekks45
    9 May 2004
    And you just have to hand over ONE kidney for it! Even better!
  6. samkiller42
    25 Apr 2006
    Linus has already taken it apart:
    Sam
  7. Gareth Halfacree
    4 Dec 2007
    Innovative, but effective? I'd need to see it first-hand to be convinced. The whole point of liquid cooling systems isn't that they're magically more efficient than air cooling systems; it's that they let you take the heat away from the ickle-tiny-hot-thing and move it somewhere you can give it the surface area and airflow it deserves. If your radiator is no bigger than a heatsink would have been - in fact, potentially smaller thanks to the need to make room for a pump and radiator - then there's no reason liquid cooling would be better.
    Dogbert666 likes this.
  8. Wakka
    23 Feb 2017
    Not quite true - you can get away with a considerably smaller radiator than conventional heatsink while achieving the same cooling potential because almost all giant heatsink stacks connected to heat-pipe assemblies have "dead zones" where no heat transfer actually takes place (or even worse, overlap when the pipes are positioned too close), whereas in a liquid cooling radiator, the tubes are spread evenly over the entire surface area.
    It's why you need something like a Dark Rock 3 or NH-D15 just to match a slim 120mm AIO cooler.
  9. Gareth Halfacree
    4 Dec 2007
    Yes and no: a bigger reason is, as mentioned in my original post, airflow. A heatsink on a graphics card - and I'm talking about the top-down stuff, here, not the centrifugal blower ones - has limited airflow because the air comes from the top, down through the fin stack, and smacks hard against the PCB. A radiator, properly installed, lets you blow air in one side and have it come out the other entirely unmolested in a straight, efficient line. Pop the same radiator flat up against a PCB and that's gone.
    You can try it yourself: measure your temps with an unobstructed radiator, then pop a bit of plastic with sticky-up bits against it and measure again.
    Be careful when comparing air to liquid cooling, though: there's another issue, and that's thermal capacity. The water holds heat better than metal, so an air cooling system and a liquid cooling system with otherwise equal performance will see the temperatures rise more slowly on the liquid cooling system - but also fall more slowly at the other end of the test.
Tags: Add Tags
