Challenge: Help ID Electronic Components from Pictures
Discussion in 'Hardware' started by smportis, 13 Jul 2007.
  1. smportis
    smportis What's a Dremel?
    13 Jul 2007
    I could really use everyone's help here. I've been trying to work on this for a long time.
    I am trying to rebuild a simple circuit board that has a bad component in it somewhere.
    It is a speed controller for a 120vac uh, um, fan, yea, that's it, a fan (actually it is a commercial food mixer, I know, I know this is a COMPUTER hardware forum, not a restaurant equipment forum - but this is the only place I was familiar with that had electronics experts.... Hey, it is an interesting exercise for all you folks who understand electronics. Plus, I build PCs, so.... Help already!)
    Please see the pics: http://picasaweb.google.com/smportis/SpeedController.
    Comments with the pictures.
    I can ID the resistors, no problem.
    1. I can ID the capacitors, but can't find where to purchase them to match exactly. See below for my attempts to id and find matches.
    2. I can't ID the diode - what are its specs?
    3. I can't ID the black component - labeled as a "TR"?
    I need to purchase matching components. Have been looking at Digikey.com and Newark.com.
    Can the components experts help me?
    Thanks a ton!
    Scott
    Components identified:
    There are 3 capacitors:
    1. 473J 400v
    The cap pictured above has the code 473J which translates to:
    47 * 1,000 = 47,000 pf or 0.047 uF
    The J indicates a tolerance of +/- 5%
    Size: 10 mm Long(L) x 9 mm high(h) x 5 mm thick(b). Width between leads(e) is 10 mm
    b: 5mm
    h: 9mm
    L: 10mm
    e: 10mm
    Parts listing from Digikey Catalog:
    - 400vdc/200vac 0.047uF ±5% b:5.0 h:11.0 L:13.0 e:10.0 Digikey Part No:495-1239-ND Cost:$0.31 B32521C6473J, http://dkc3.digikey.com/PDF/T072/1466-1468.pdf
    - 400vDC/200vac 0.047 L:12.0 b:5.0 h:8.3 e:10.0 1.0 0.6 EF4473-ND .48 3.50 25.00 90.00 140.00 ECQ-E4473KF, http://dkc3.digikey.com/PDF/T072/1466-1473.pdf
    2. & 3. 104K 400v (x2)
    10 x 10,000 pf = 100,000 pF = 0.1uF +/- 10%
    Size: 15 mm Long(L) x 11 mm high(h) x 5 mm thick(b). Width between leads(e) is 15 mm
    b: 5mm
    h: 11mm
    L: 16mm
    e: 15mm
    400vDC/200vac .10 ±10% b:5.0 h:11.0 L:17.5 e:15.0 DK PN: BC1793-ND 3.46 BCComponents PN:2222 373 51104
    400vdc/200vac .10 ±10% 5.0 10.5 18.0 15.0 495-2452-ND NEW! .44 3.27 23.33 B32522C6104K, http://dkc3.digikey.com/PDF/T072/1466-1468.pdf
    Resistors from left to right:
    100K +-5% x 1 (100K H-ND)
    15k +-5% x 2 (15K H-ND)
    100 +-5% x 1 (100 H-ND)
    Purchase: Yageo 5% Carbon Film Resistors
    http://dkc3.digikey.com/PDF/T072/1598-1600.pdf
