Electronics Change PSU power switch
Discussion in 'Modding' started by Javerh, 20 Jun 2007.
  1. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    I'm planning on getting an Enermax Liberty 500W and was wondering if it is possible to change the usual ON/OFF - switch at the back. I would prefer something like
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=118&products_id=662
    The led is not a problem, but I can't figure out if the original switch is connected to the full 230VAC (or 115VAC). Looking at an old Enermax 300W psu the switch is indeed rated 250VAC. Is that just a safety precaution or a surefire sign of imminent failure?
    If I can't use the new switch directly, is there a simple way to bypass the original switch with a relay?
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    The switch at the back switches 230V mains. You can't use a relay without another power supply to power the relay :)
  3. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Any mains raited switch (for your location...) with enough amperage capacity will be fine to replace it with.
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I'm just curious - how come you want to replace that switch?
  5. Javerh
    5 Sep 2006
    I want to put the switch about 5cm behind the psu. I was originally planning to put it next to some other buttons that control lights etc. Therefore I wanted them to be similar but now I'll have to come up with a back-up plan.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    PSU switches are a damn nuisance; last time I had my case open I accidentally turned it off, then couldn't understand why the system wouldn't boot... :blush:
  7. capnPedro
    11 Apr 2007
    I replaced the switch with one of these illuminated switches. I kept knocking the power off by accident when doing something with cables behind my NAS server.
  8. Javerh
    5 Sep 2006
    Sounds good enough. I'll get something like that then. Thanks for the help.
  9. ConKbot of Doom
    2 Jul 2003
    You could remove the switch from the system however, if it would be more convienient. The ATX12v 2.2 spec says that it may be ommited since the mains connector can be used as an equipment disconnect.
  10. Javerh
    5 Sep 2006
    That's an interesting idea actually. No more guessing whether the switch is on or not. Thanks for the tip.
