changed mobo, user desktop folder cant be copied
Discussion in 'Tech Support' started by psYCHopath, 16 Jul 2006.
  1. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    :duh:
    I helped my friend to change mobo since the original ones cant be booted and added a new 80GB hdd
    so now its new mobo, windows in new hdd(primary hdd), old hdd data was slaved. When the windows XP Pro installation was completed i couldnt access the old hdd "Desktop" folder "D:\Documents and Settings\Administrator\Desktop" heck even "D:\Documents and Settings\Administrator"
    is there a way for me to retrieve the data back? :idea:
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Im guessing it says its password protected or something like that. Just boot into the safe mode and transfer out all the data you need. Had the same thing happen on my moms laptop.
  3. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    i had a similar problem transfering documents over to a pc. I found that as long as i used the same username and password as before it was fine
  4. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    or use permissions to take ownership of the folder & files.
  5. psYCHopath
    25 Dec 2001
    @tm36usa, this way couldnt work since i cant even access safe mode. (windows is not swap bootable if you use diffrent mobo)
    @TheoGeo,hmmm great idea....will try that and let you guys know the result.
    @BUFF, i cant even get the "desktop" folder properties cuz it show "0" files and "0" kb
