Windows Changing the title bar text
Discussion in 'Software' started by GiGo, 19 Jun 2003.
  1. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Ok seems odd, but I was wondering if you can change the titlebar text in any window I want.
    Or if anyone knows (or uses) crazy browser how to change the title of that.
    Cheers
    >> GiGo <<
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    In MS Word you can do it with an autoexec VB macro. Have you looked in the registry for the browser title?
  3. GiGo
    12 May 2002
    Ah found a small program now YAY
    Works well which is cool, displays other things aswell if I want inculding the time.
    I did try looking through the registry and it wasnt there also tried rees hacking it but its compressed some how (tired UPX on it but didnt work) also tried to Hex edit it! NO success.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    And do we have to beat a link out of you? :grr: ;)
  5. GiGo
    12 May 2002
    Um... sorry got it from download.com search for 'title bar reader' its completly free and it can scroll anything you want or dispaly enyhitng you want, also rotates itself aswel, looks good :D
  6. dakar
    dakar What's a Dremel?
    6 Mar 2002
    Under 2000 and XP you can brand or 'tatoo' the window for Internet Explorer to say whatever you want.... the easiest way is through a policy across a domain OU, but there should be a reg hack for it as well for a standalone as well... look for tatooreg in the registery or googlize it and it'll show up.
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    IE (and OE) are no problem, XSetUp will swap the titles. They're designed to be customised for all the free ISP cds. ;)
    For Word, the Autoexec macro is
    Code:
    Option Explicit
    Public Sub Main()
    Application.Caption = "Howard's Word, OK!"
    End Sub
