Character encoding?
Discussion in 'Feedback & Suggestions' started by ch424, 15 Apr 2009.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hello
    I keep seeing things like this:
    Is this my problem, the posters' problem, or bit-tech's problem? I don't think it's my fault because it happens in IE, chrome and firefox on both of my computers, and most of the time £ symbols show up fine. I see that in the source code it has character encoding as a meta tag - is it sent in the HTTP header too?
    It's not a major problem, but it would be cool if it were fixed!
    Thanks for all the good work
    ch424
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    It is part bit-tech's fault, part browser fault.
    Site and forum use different character encoding and it causes a headache whenever I look at fixing it.
  3. ch424
    26 May 2004
    Haha, that's always my attitude with character encoding too :p Thanks for the reply.
  4. Krikkit
    21 Jan 2003
    I have the same problem on numerous websites too, it's not just here. A good example is on Pistonheads classified ads - very often the pound sign isn't converted properly.
    Sounds like a real headtwister!
  5. azrael-
    azrael- I'm special...
    18 May 2008
    It's a subtle ploy to make you use Euros instead... :p
