Electronics Charger for 4x3.7V li-ion batteries?
Discussion in 'Modding' started by quizz_kid, 18 Aug 2013.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi.
    I going to have 4x3.7V(=14.8V) li-ion batteries connected in serial and built inside a box, and I want to be able to recharge these.
    Would something like this work?
    The cells are 4900 mAh each
  2. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Should be fine. Just make sure you ALWAYS use a battery management protective circuit and wire the charging circuit to it if you haven't already. You don't want anything blowing up.
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    It will work fine. I recommend finding old laptop battery with same voltage value and using circuit of that battery,
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Here are the specs of the batteries I've got:
    Voltage:3.7V
    Capacity:4900mAh
    Rechargeable battery with PCB
    High rate discharge,no memory effect
    Short circuit,over charge and discharge protection
    PCB life is around 10 years
    It is green
    It says it has protective PCB... I bought them cheap on Ebay though. Should I consider another circuit?
  5. Darkwisdom
    27 Aug 2011
    A lot of the time those cheap ebay ones can be okay. The Protective circuits however, can be a bit dodgy. Despite being from the UK, i've found www.batteryspace.com to be the best site around.
  6. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Could be worth spending some extra $s for safety reasons here I guess. Thanx Wisdom!
  7. Darkwisdom
    27 Aug 2011
    That's the truth. In a portable console/computer, the worst thing to go is the batteries. They could take your whole project with them!
