Graphics Cheap 580 GTX!?
Discussion in 'Hardware' started by LightningPete, 4 Aug 2013.
  1. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    hey folks, looking at the GTX 580 it seems a really good price at 137.50 on scan
    What does everyone else think? Is this a good buy?
    Upgrading possible from a GTX 285 with a Q6600 oc to 3.2ghz
    how much benefit will i see on a 1920x1080 for gaming?
    e.g. Planetside2 / arma2 / arma3 / BF3 etc
    http://www.scan.co.uk/products/1536...r-1544mhz-512-cores-mhdmi-dual-dvi-oem-brown-
    Ive looked on GPU boss but with the games I play I cant see a direct comparison.
    Cheers
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    you have a gtx 285 or 275?
    either way that looks like a good deal
  3. teppic
    teppic What's a Dremel?
    18 Jul 2011
    If you get a 7870 LE for £25 extra it'll outperform it easily, have more memory, use far less power, and be supported longer. (In other words, no, I wouldn't get one)
  4. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    I have to disagree, the 7870 LE won't stomp all over it as suggested. They'll trade places as fastest depending on the game being supported longer isn't really a real world issues when you consider that the 7950GX2 I've got in a box is still supported by some fairly recent titles (in fact by one one that's still currently in beta ;) ).
    In short: It's a good deal, so is the 7870 LE. Depends on whether you can afford the extra £25.
  5. teppic
    18 Jul 2011
    By supported I don't mean won't run anything at all, rather that Nvidia has absolutely zero interest in the 580 now, while AMD is still actively developing for the 7000 series.
    The 7870 LE won't stomp all over the 580, no, but on recent drivers it won't be trading places, it'll be ahead. The regular 7870 would trade places, though.
    Given the memory limitations (less than 2GB is seriously a problem for games going forward) and the power use, I wouldn't get the 580.
  6. docodine
    10 Feb 2007
    teppic is right, but it all depends on what OP wants to spend
    for that price the 580 is good, at its own price the 7870xt is better, and three titans is better yet
  7. teppic
    18 Jul 2011
    A £25 difference isn't quite three Titans :) Plus you should get some free games with the 7870 LE.
  8. cookie! nom nom
    cookie! nom nom Minimodder
    27 Apr 2012
    you also get them with the 580 :D
  9. teppic
    18 Jul 2011
    1 vs 4 with Aria's 7870 LE :p
  10. Throbbi
    10 Sep 2009
    Now that makes the difference. If they're games you have or don't want you can easily get £5-10 a pop on here which could conceivably drop the 7870 price to £15 (best case scenario) less than the 580 and that is a clear no brainer.
  11. monkeydud
    monkeydud What's a Dremel?
    21 Jul 2010
    Would the 580 make a good upgrade to the 5850?
    Sent from my HTC One X using Tapatalk 2
  12. cookie! nom nom
    27 Apr 2012
    yes but in my time of owning a 7xxx card i have found them unstable in a number of games, and seems to me the 580 is a more stable card.
  13. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Maybe someone should throw up a few links showing these cards being tested with new drivers.
  14. monkeydud
    21 Jul 2010
    Would be really handy. Think I might just hold off and save up abit more.
  15. LightningPete
    2 Jul 2009
    Thanks for the reply folks
    Ive currently been lazy not doing any OT at work so currently cash is strapped to minimum spends possible and saw this little gem on facebook by scan. So just querying vs 285 is it worth the upgrade for the price? :)
  16. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    £155 for a 580 is not cheap. They sell for £100 used.
  17. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    OP says it's £137.5 not £155??
  18. LightningPete
    2 Jul 2009
    its 137.50
    and id rather new than pre-owned for reliability / warranty / not burned out before i use it etc
    Also is it going to be worth the upgrade, its not just about the price. I cant seem to find via google or otherwise a direct comparison for the games I play
    My rig:
    Q6600 @ 3.2
    4GB DDR2
    P5Q Asus S775
    650W etasis
  19. AlienwareAndy
    7 Dec 2009
    Sure they were £155 last week.
    Any way I wouldn't buy one. They're old technology and use a fair chunk of power. Personally I would go with one of these.
    http://www.scan.co.uk/products/2gb-...08mhz-gddr5-gpu-1033mhz-boost-1098mhz-cores-9
    Which would be pretty close in performance terms, fully retail boxed and uses way less power.
  20. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    Might not be the optimal experience some games recommend a I5 750 or up now.
