Other Cheap caliper
Discussion in 'General' started by silk186, 29 Nov 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    Are the cheap callipers on eBay any good? Every so often I wand to measure something to order a replacement part so it doesn't need to super accurate, but it would be nice if it is accurate to 0.1mm
    Are the cheap ones on ebay accurate and good enough for the odd measurement or do I need to spend a bit more?
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I got a digital calliper from Lidl, think it was about 10 quid, seems to measure ok.
  3. silk186
    silk186 Derp
    1 Dec 2014
    Seems I can get a cheap one for £3.99 or pay a bit more £10-15
  4. legoman
    legoman breaker of things
    28 Feb 2010
    Got a Lidl one years ago, its decent enough.
    silk186 likes this.
  5. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    They're 'OK' if you strip them down and clean out all the swarf and other detritus left in them from manufacturing.
    I wouldn't be without my Mitutoyo verniers or micrometer, but appreciate a cheapo for when bodgery is a foot
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    we use ones that look identical at work and we're working down to thousandths of an inch. If I measure diff shims they're usually accurate to a few thou. The way you measure and whether it's the right tool for what your measuring is usually the limiting factor.
  7. silk186
    silk186 Derp
    1 Dec 2014
  8. David
    7 Apr 2009
    yeah - I bought a cheapo £15 digital model a few years ago and tried it out on a mate's slip gauge set. It was good to within two or three thou.
    My only gripe is it has no auto power-off and I have occasionally left it switched on. Bloody frustrating, but I've learned to keep a couple of spare button cells in the case.
  9. silk186
    silk186 Derp
    1 Dec 2014
    That sounds more than enough for my requirements. ordered!
  10. Nexxo
    23 Oct 2001
    Banggood is your friend.
    A warning though: this webshop is the crack cocaine of tools and gadgets. Lots of interesting stuff at crazy cheap prices. I have just bought an ES121 electric screwdriver from them and it arrived here within a week.
    Arboreal likes this.
  11. silk186
    silk186 Derp
    1 Dec 2014
    Interesting, it looks like taobao and ships from China,
  12. Nexxo
    23 Oct 2001
    Yup. My first experience has been pretty good. It quotes prices in GBP; you can pay through PayPal. I ordered on 17.11.19, it was shipped on 19.11.19 and it arrived on 26.11.19. You can track your order on the website every step of the way.
    It's just, as I said, incredibly tempting to go on a spending spree: digital multimeter/oscilloscope for £57,42; multifunctional component identifier/tester for £15,73; non-contact laser thermometers from £7,07; and this really nice large LCD screen digital calliper with metric/inch/fractions for £24,21. Must... resist...
  13. d_stilgar
    d_stilgar Old School Modder
    11 Feb 2010
    I got a cheap digital caliper and have loved it. I'm not a machinist, so I don't need something accurate to .00 thou or whatever.
    The biggest issue with it is that the reading seems to be based on some relative voltage/resistance reading, so if the batteries are low that number will move, even if the calipers aren't. The cheap ones also slowly drain the batteries when not in use, so it's best to take them out.
    But if you only use it once a month or so and it's not for critical work, there's no reason to spend a lot of money.
  14. silk186
    silk186 Derp
    1 Dec 2014
    The Caliper looks identical to the, thought a different brand, to the one I ordered of Amazon.
    Digital Vernier Caliper, Preciva Electronic Caliper 150mm
  15. legoman
    28 Feb 2010
    I could really do with a 4"/100mm caliper for my box but its hard to find a half decent one.
  16. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    If you can squeeze in a 150mm caliper you can find Mitutoyo vernier calipers, on Amazon, for less than £30. I intend to buy one next year, should never need to replace it.
  17. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Think my Lidl one doesn't have an auto off as my battery was dead and I've only used it a handful of times, put a new one in and all's fine again.
  18. Nexxo
    23 Oct 2001
    No fractions though. Never use it, but it's handy to have if you deal with older British engineering blueprints in Imperial.
