A/V Cheap coax or optical S/PDIF DAC
Discussion in 'Hardware' started by Cupboard, 16 Feb 2011.
  1. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Having had issues with onboard sound, external sound cards and an internal sound card with high pitched squeaks which change note depending on what my computer is doing, I'm investigating using the optical output from my motherboard.
    Basically, I'm after something cheap that will take the S/PDIF output and give me sound! Doesn't have to be massively high end or have loads of features, the simpler the better. Any suggestions?
  2. Deders
    Deders Modder
    14 Nov 2010
    have you tried any of those with your current PC?
    Are you sure it's the soundcard? some components squeal when under stress, some GTX260's are famous for it, motherboards can also be the culprit. Did you try turning your speakers off to see if the squeal went away?
  3. docodine
    docodine killed a guy once
    10 Feb 2007
  4. Cupboard
    30 Jan 2007
    I have tried all of these with my current PC and it is definitely the sound output not a component. It will be being caused by a different component but I'm not sure what it is. Based on the fact that it gets worse when my computer warms up, I'm guessing it is the PSU.
    Given that I still have issue using two different external sound cards, will an EMI shield help?
    edit: I've now tried it with the onboard coax S/PDIF output using a bodged header to Phono pin jack cable, and that works fine with no squeaking. Unfortunately, I have to give the thing I'm using as a DAC back :( Currently, my computer has a 31 band GEQ sat on top of it :p
  5. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  6. Cupboard
    30 Jan 2007
    That's one of the USB ones I've tried and it has squeaky issues, same as everything else. Thanks for the suggestion though, it's been really good on my laptop which has got awful audio output (but no squeaks!).
  7. Mister_Tad
    27 Dec 2002
    Beresford DACs are good for the money - a lot of hype, but don't pay any attention to that (no they're not the best DAC in the world), but cheap and decent.
    http://www.beresford.me/main/main.html
  8. Cupboard
    30 Jan 2007
    They look really nice, however they have more features than I need (I only need one input) and are way out of my price range unfortunately.
    Damn this "doing this on a small budget" lark :p
  9. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
  10. Cupboard
    30 Jan 2007
    That would be ideal, thanks :)
    edit: I'm such an idiot, why did I not think of looking on Amazon? I searched through ebay (the only affordable ones were dodgy looking Chinese ones) forums etc. Silly Cupboard.
    edit2: got one for £29
    edit3: finally got it all working, and with the optical connection it's great. Still had the issues with the coax one, but hey ho.
    So, thanks for all the help :)
