ya, what are some good but cheap ear bud headphones? the ones that like stick out and fit inside your ear, not the crappy ones that fall out this is an example of what i have, and i hate and do NOT want http://www.geeknews.net/images/ipod-earbuds.jpg i want somethin along the lines of this http://www.pureaudioblog.com/images/2005/12/griffin-earbuds.jpg good but not expensive
I have a set that goes in the ear canal and all I can say is they are pretty uncomfortable imo. They also block out all the surrounding noise (which isnt good from a saftey aspect if you are cycling) and they really dont sound all that great either, they seem to lack top end and have too much mid/bass. Obviously at the end of the day its subjective but I would reccomend something more like a set of Seinheiser MX500's.
Those ones that go into the ear are supposed to be quite bad for your ears. Sony do a pair for about £30 which are good if you can get past the discomfort!
I got a pair of sony ones like the ones you like. They are great! Don't get cheap ones, they will fall to peices/crackle/have generally poor sound quality. Get good ones, they are super fantastic
I have a set of the earbuds (EX71s or something) that everyone is talking about and i've no idea how you can say they're uncomforable - are you all using a sheath that's too big?
Sounds likely. The EX71's or sony's newest version of the same thing are basicly your only option. Asking for cheap but good with headphones is like asking for black but white. It's quite hard to satisfy. The EX71's(or 72's or whatever) are going to be a setup from the most basic of earphones, but that's about as far as it goes.
I have a pair of the sony ones and they sound good but has anyone else found that the make your ears ichy and waxy? Moriquendi
they feel fine to me, and they are better than the ones that dont go in, cuz those fall out like a biatch
If you stick anything in your ears it'll make them itchy or waxy hence the reason they aren't good for your ears. Just spoke to a friend of mine who has the £30 sony earphones - he said they're good but has had to replace them 3 times in 2 years because the strain relief on the 3.5mm connector isn't good enough.
I agree with biosniper i've got both the sens and the sonys. The sonys are a little too basy but they do block most of the noise, great for walking to work or working. But the sens sound fantastic especialy for the price.
these are brill. KOSS Stereo In Ear Ear Plugs - The Spark Plug Avalible at amazon ... I've got a pair and the sounds is brilliant, virtually no noise intrusion as all and very soft comfy fit. The bit that goes in the ear is made from that compress foam stuff (that ear plugs are made from), so you compact it - stick it in your ear and then it form's to fit any size.
Sony hands down, cost me about £25 (or £35?) from argos, most fantastical although the latex around the cord is weak and will perish in your pocket!
All of u lot are talking about Sony being good? are u lot mad? Anyways my choice is Creative labs- EP630 £20 and they are rebadged Audio Technica ones i believe, These are much better than the Sony rivals.
I had the SONY EX-81 'phones. They are like the 71s but have a bit that go up and around our ear. They seemed quite comfortable, but were too quiet and blocked out surrounding noise too much. Plus the insulation on the cord all wore away and disintegrated, causing them to stop working. _C
Creative EP-630's are like the sonys only designed better. Id reccommend them highly. Best way is to search EP-630 on Amazon, best price anywhere.
