Electronics Cheap IR remote control
Discussion in 'Modding' started by Guest-2808, 30 Jan 2003.
  1. Guest-2808
    Guest-2808 Guest
    I didn`t put this in the guides forum because it`s not a complete guide, just a hint really.
    I have been using these little devices for years:
    http://www.mygizmos.net/frames/hardware/irreciever.html
    The original creator seems to have dissapeared, but everything you need to make on is on that web site. You can use stripboard if you don`t want to make a PC, it`s fairly simple.
    If a bunch of people want a programmed PIC, get together and email me and I`ll see what I can do.
    Once you have a UIR, get the Girder software from http://www.girder.nl .
    Go to Cutprice and get a "Tornado" remote control for £5.99. It can control 2 TVs, 2 VCRs, 2 Cable/sat boxes and 2 DVD or HiFi components. Program one of the AUX buttons to code 134 which will work great with the UIR. You may need to set a repeat delay in Girder for some commands.
    I use mine to watch DivX movies and DVDs, very handy. Check out Media Player Classic, I can post my Girder config if anyone needs it.
    MoJo
  2. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    I make these :naughty: and they work really well and fit in the Serial connector housing.
    I also make IrDA connectors! (Site to be updated soon)
    Meblin
  3. Guest-2808
    Guest-2808 Guest
    Interesting... on the one hand, they are cheaper and don`t require a programmed PIC. Also, the software may be more fleixible for reading.
    The main thing I like about the UIR, and the reason I used it in my original in-car MP3 player ( http://amimpc.world3.net ) is because the uproc does all the work, and the computer just sits there until it gets an interrupt. Not much of a concern on a 2GHz machine perhaps, but in my car system I was running close to the wire...
    I guess I just love efficiency too :D
    MoJo
  4. joebloggs
    joebloggs What's a Dremel?
    1 Feb 2003
    Does Cutprice has a web site or is it a retail outlet only? (Never heard of them in the UK)....
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Welcome to the boards, joebloggs. Most any remote would work, so the Argos catalogue is one source. ;)
  6. joebloggs
    1 Feb 2003
    True - but I like the sound of a £5.99 Remote ;)
