Electronics cheap LCD touch screen?
Discussion in 'Modding' started by 273BeLow, 21 Aug 2004.
  1. 273BeLow
    273BeLow What's a Dremel?
    13 Apr 2002
    Hey not posted in a while since my media box pc well time for a new project :)
    just got myself a new car a Renault Laguna 1.8 RT to be exact.
    going to start building a car PC at the moment but need to find a cheapish LCD tochscreen quality doesn't have to be amazing it will just be for menus/sat nav.
    The Lilliput 7" TFT LCD touch screen seems great but is £200 there must be something cheaper out there or.. if paying that price are there any DIN units (the ones where the LCD folds away into the space your stereo was) that have a touch screen? I can only see non touch screen models :/
    Cheers
  2. pdaoust
    pdaoust What's a Dremel?
    23 Apr 2003
    Unfortunately 'cheap' and 'touch' generally aren't seen in each other's vicinity. If you don't mind shopping the other side of the pond, though, you might want to check out EarthLCD; they have decent prices.
  3. infernis
    infernis What's a Dremel?
    5 Jan 2003
    I saw that the Lilliput 7" displays are 179 pounds, which is pretty competitive to prices here in the U.S., but that VAT sure is a killer. Still, I couldn't imagine finding it cheaper in the UK unless you guys went on a group buy or something. I wouldn't suggest going any cheaper than Lilliput, if you're going to go with a touch screen display.
  4. coorz
    coorz Miffed
    25 Apr 2003
    Have a look on e-Bay. Possibly score a separate touchscreen kit and mount that on a display.
  5. nizon
    nizon What's a Dremel?
    15 Mar 2004
    Hmm
    I have the exact same project on my to-do list when I get a car
    Touch screen LCD and all
    I also want one of those LED displays in my rear window... great for getting rid of tailgaters, or saying thanks to those nice few people who let you merge
  6. relix
    relix Minimodder
    14 Nov 2001
