Graphics Cheap / low power Physx card
Discussion in 'Hardware' started by PhoenixTank, 21 May 2010.
  1. Guest-44432
    Guest-44432 Guest
    Did you watch the youtube vid on page 1 of these thread with physx on and off?
    I would say so.
    Also yes you do need your Ati card installed first.
    Cheers,
    Simon.
  2. iwog
    iwog Linux cursed
    14 Jun 2007
    Thank you so much for clearing that up, as I dont play any of the games on this page I think I'll save my money until there are some that I do play.
  3. Guest-44432
    Guest-44432 Guest
    I wasn't quoting I was getting a performance gain from Crysis with Physx enabled.
    I was stating that with my other 2 side monitors running on my 9800gt rather than on my 5970, it was giving me a performance increase.
  4. Guest-44432
    Guest-44432 Guest
    To prove physx is working here's my before and after enabling physx.
  5. robots
    robots What's a Dremel?
    27 May 2010
    That's what I think too. I'm sure something will come along to make it worth while eventually though. Maybe Mafia 2? But if you can get an old nVidia card for about £35 then that's not bad. Although I don't have a spare PCI-E slot :(
  6. Nikols
    Nikols What's a Dremel?
    13 Oct 2009
    It's definately not a must, nice to have the option of a hybrid system tho even for options such as two + monitors without a performance hit, hardware acceleration of video editing (have to try this yet but the nvidia gpu can be activated for this in catalyst), nvidia 3d vision on ur second monitor. I like the idea of having the best of both worlds, the ability to run physx and enhance games that use it. Thanks to fermi I picked up a gtx 280 for €100 which puts it in a price range that means it's not a massive outlay
  7. murraynt
    murraynt Modder
    6 Jun 2009
    Can you run a nvidia card for physx and an ati card for graphics since sli is not required?
