Modding Cheap neon (im going to cry)
Discussion in 'Modding' started by Buttcrack, 10 Oct 2002.
  1. Buttcrack
    Buttcrack What's a Dremel?
    29 Jun 2002
    I just broke my 19" U shaped cathode *WAHHHH* so i was wondering if anyone knew a place to get cheap neon/cathodes? *sniff* thanks
    :waah: :waah: :waah: 20$ downt the drain...
  2. Phire
    Phire Performance-PCs.com
    11 Jan 2002
  3. Buttcrack
    29 Jun 2002
    that looks like a pretty good deal, 15$ for a tube and a dual inverter... I was thinking, since i still have my inverter from the one i busted, i would buy a 15$ kit and 2 tubes, 1 for the 2nd plug on the dual inverter, 1 for the inverter i already have.. but, does anyone have any suggestions on how to mount the 2 plain tubes? the kit comes with little peel and stick mounting feet that i assume is like the cathode in the most recent review.
  4. Yammosk
    Yammosk What's a Dremel?
    8 Mar 2002
    Bugger that would be really anoying considering the price of cc's over here i hope i never do it !!!!
    Yammosk
  5. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    walmart still carries 10$ sound activated neons.. :)
    -scoob8000
  6. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    :eeek: :eeek: thats like £6!?!!?!?! and i'mstuck here in england? where it rains and cathodes come in £20!?!!?!? i'm moving.....
    dude....someone in the US should buy loads of them and sell them to us brits....pack them right they wont break....and even inc. postage and a l'il profit it wouldnt come close £20
  7. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    Theres a difference, he has said Neons, not cold cathodes.
    Also cheaper to ship things into the US...
  8. bAnTAi
    19 May 2002
    yeah...but you only need to make the right inverter......
    and sound activated!!!!
  9. Lazy
    Lazy Meow?
    13 Nov 2001
    the cathodes from walmart are very dim apprently. Changing the invertor would have no effect on their brightness.
  10. bAnTAi
    19 May 2002
    can anyone verify lazy?
  11. Lazy
    Lazy Meow?
    13 Nov 2001
    use the search function as someone bought a few awhile ago and posted pics
  12. Hindaine
    Hindaine What's a Dremel?
    23 Oct 2001
    Except that they are 10 inch neon tubes, yes, but with all the plastic sh!t it comes with, they are 17 inches long. I bought one because it was cheap and ended up having to do a lot of modding to get it to fit.
    the auto-parts store by my house has 9 inchers for 14 and they are pretty damn bright
  13. hprcrazyguy
    hprcrazyguy Minimodder
    31 Dec 2001
    Yeah, the WalMart ones are ok, but not that great. I got one and also had to mod it to fit into my case. :( They have a decent brightness, but you cant really tell the difference between night and day shots.
    [​IMG][​IMG]
  14. scoob8000
    17 Feb 2002
    yeah, their not the best, but they are only 10 bucks.. :p
    -scoob8000
  15. ejmac
    ejmac What's a Dremel?
    31 Jan 2002
    I have a walmart one too....decent bightness but it barely fits in my Antec 1030. It is also pretty big around.....like the size of a broom handle so if you have anuthing other than a full tower forget it. It needs no inverter though, it must be built into the tube part....just slapped a molex on there and was good to go. I was in there and said for $10 how could I go wrong :hehe: And SVC is the cheapest I have seen CC's at.
  16. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    heres what i did with my walmart neons.
    cut them outta the casing with a dremel.
    you get a CC sized stick with an inverter, about 10" i think
    save the rubber spacers, they come in handy.
  17. criminally insane
    criminally insane What's a Dremel?
    22 Jul 2002
    $34 for Blue CCFL and $29 for a tri-colour cold cathodes here dunno what they are like tho
    jaycar also sell cold cathodes (minus inverter) for $22
    all aussie prices :)
    us australian look after each other :p
  18. Bighods
    Bighods What's a Dremel?
    9 Sep 2002
    Just got my new bloo cold cathodes through this week. I brought them for a bargain price of 3.96 each from here
    Cheap cathodes
    Installed it today and these things are really bright. You can buy the inverters there as well for a whopping 3.34!!
    They are UK and ship really quick.
    Hods:D
  19. bAnTAi
    19 May 2002
    Bighods you are a life saver, well done for finding.....glad to see some company has seen the market for cheap cathodes......
    Do they come in anysort of tubing?
    Welcome to the forum....
  20. Bighods
    9 Sep 2002
    Thanks:D
    They are sent in a protective tube, but other than that no. The inverter you can get with them is tiny and v.v. easy to use. I shielded mine inside a small plastic box (ironically from a dremel case!)
    I havn't had much experience with CC's but to me these seem really bright and light up my case superbly, through the window and front bezel. They are very thin so be careful with em.
    Had to be worth a try for under 4quid!
