1X AMD ATHLON XP-M 2500+ SKT-A OEM BARTON (Mobile)(unlocked) 1 X DFI NFII ULTRA INFINITY Rev A 1 X Sapphire ATI RADEON 9800 PRO 128mb 1 X Lain li PC-60 1 X Antec TrueBlue 480 Watt PSU 2 X Kingmax PC3500 512MB DDR400 CL2.5 What do u think, im hoping to hit 6000 3d2003 marks and 19000 with 2001 aswell as 40,000+ aquamarks after overclocking(with cooling) this system. Built on a tight budget i know, but do u guys think?
lol, where? if that's a tight budget then i dunno what a big budget is. Welcome to the forums. Change the ram, you want as tight timings as possible cas2.0 is a must, and is 1gb really needed? if you are on a 'budget' i'd get a psu that doesn't cost £90 lol and get less but better ram.
I belive Kingston HyperX is the choice of overclockers at the moment, tho anything that runs 2,3,2,5 will be ideal. as mentioned, you dont need a gig of ram, 512 will be fine, and if you can find one, the rev b DFI's are mroe clockable than the A's....
a decent 350w psu (enermax/antec) will do ya. definately get a revision b board. or do you have those parts allready? you will go past 4000 on aquamark, once that cpu goes beyond 2200mhz its nealry all down to the graphics card. shouldm be good for 6k on 3dm03 aswell, as for 2100 on 2k1 i am unsure.
