A/V Cheap, not terrible TV
Discussion in 'Hardware' started by Ljs, 10 Aug 2018.
  1. Ljs
    Ljs Well-Known Member
    4 Sep 2009
    I've back with my parents for a bit (ouch) and need a TV, but I haven't really kept up with things.
    The room is a reasonable size but I don't want anything too big so around 40 inches. My plan is to use it as my primary TV until I'm settled in my own place again and then move it to my bedroom. I don't watch terrestrial TV and will just use a Firestick. Not sure if I'm bothered about 4k (you don't miss what you've never had).
    Not the most exciting, but any suggestions?
  2. silk186
    silk186 Derp
    1 Dec 2014
    If it is going to be a bedroom TV does it really matter? I picked up an LG 42LB5500 42" 1080p for £120 on gumtree a few years back. It's connected to my computer with Sonarr with a set of Microlab FC 360 2.1 Channel Speaker. I've been very happy with the setup. As long as it is a decent brand and doesn't look ugly you should be fine. I would recommend a sound bar or 2.1 set of powered speakers.
    BlareFlipTed likes this.
  3. silk186
    silk186 Derp
    1 Dec 2014
    Most people can tell the difference between a decent and high-end TV in terms of the picture unless they do a side-by-side test. The sounds can be pretty crap (add 2.1 speakers) and you might not have smart TV functions (add an Amazon Fire stick or similar).
