Displays Cheap or Expensive???
Discussion in 'Hardware' started by h_frost789, 9 Jan 2009.
  1. h_frost789
    h_frost789 What's a Dremel?
    25 Dec 2008
    well i'm having a hard time deciding if i should get a cheap BenQ MP512 projector for $579 and another $100 off for mail in rebate. Or should i go for the high end Projectors... Ofcource i know that the more expensive projectors have higher quality but is it worth the money?
  2. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    You might want to give a bit more detail, what are you going to use it for? what sort of setting is it going to be used in? etc
  3. h_frost789
    25 Dec 2008
    i will be using it as a gaming projector especially for the Wii, so i will be putting it in the gaming room.
