I'm wanting to make a very simple fan power control circuit and fancy trying my hand at pcb etching. Now I've read this nice little guide here http://forums.bit-tech.net/showthread.php?s=&threadid=37519 Now I'm going to do the etchin pen method and I want to check what I am about to order is suitable. All from maplins Pen : http://www.maplin.co.uk/products/module.asp?CartID=040416224149328&moduleno=2104&Products=1 Maplin code : HX02C Etching tray: http://www.maplin.co.uk/products/module.asp?CartID=040416224149328&moduleno=10440&Products=2 Maplin code: CH38R Ferric Chloride Crystals: http://www.maplin.co.uk/products/module.asp?CartID=040416224149328&moduleno=2097&Products=1 Maplin code: XX12N Polishing Block: http://www.maplin.co.uk/products/module.asp?CartID=040416224149328&moduleno=2109&Products=1 Maplin code: HX04E Copper-Clad Boards http://www.maplin.co.uk/products/module.asp?CartID=040416224149328&moduleno=2112&Products=8 Maplin code: HX00A Are these parts suitable can you recommend any different ones if not? I heard pre drilling the holes is best is that correct? Thanks Edit : I'm looking for something that will look like this in the end : http://www.bsodmike.com/stuff/DivineProtection/DivineProtection_pcb.jpg
Not IMHO, but lightly centre-popping the hole positions then joining the dots with the pen may help. With proper photo-resisted boards, you often let the copper etchant remove a spot of copper at the hole position to aid drilling, but centre-pops are to drilling as vinegar is to chips.
Or you could get the starter kit that has everything, possibly cheaper? Oh, and i found it much easier to make the PCB's by printing them on photo-quality paper (glossy) using a laser printer, and transfering it over.
An inkjet printer works fine for using uv transfer method and photo resist boards. I used an old scanner, some bacofoil and 3 of these to make a cheapish uv light box and it seems to work OK after a few test goes to get the timing right.
I second that. I used the same method, only I used silver card inside the box, and a 3 x 8 Watt 12V tube lighting circuit from an old caravan tube light. I got the UV tubes from Farnells. The 12V psu initially came from an old AT format PC, but has since been replaced with a Laptop PSU from Maplins. Will post pics of your'e interested.
