ok, a mate has just got the gigabyte SLi mobo, the one with the D.P.S. power thing. since he has a lan in just over a week he needs a really cheap but good performing SLi card, i was thinking x600 levels, this will only be for a few weeks until he gets the $$$ for some better cards 3500+ GB K8NSXP SLi 1gb ddr400 ram so what do u recommend, this will probly get sold or put into a freinds new system after the lan. thnx dman
The Radeon X300 should overclock fairly well, you might be able to get close to X600 Pro performance if you are lucky.
nor would i and here i was telling highlan3r that the x300 was to slow for me what are the 6200's like?
In the £40-50-60 price bracket there isn't a lot... depends whether you want to try a 6200 TurboCache out for fun. I don't personally think that is quite as effective as an X300 if you can get the X300 at the right price. It would also depend whether you were considering DOOM 3 on it or not... Give this a read, should give you an idea: http://bit-tech.net/review/390/3 I talk a lot about value in the conclusion too. Edit: the 6200 TurboCache would be a little faster with 1GB of memory, notice I tested with a very 'entry level' system: Pseudo 3000+ & 512MB RAM
I'm assuming when you say "SLi card" you mean "PCI Express card". Because the only SLi(-capable) cards are 6600GTs, 6800GTs, and 6800 Ultras AFAIK. If it's a temp solution, either the x300 or 6200TC would probably work. Not work well, but work.
iv found the sapphire X300XE, however i cant find it on there site, thought it was a typo from my pricelist untl i googled it, does anyone know what the difference is between the XE and the SE? and what turbocache card should he get? the 16mb upto 128 mb or the 64mb upto 256mb? only a $18 difference
The X300 is truely truely crap for gaming though, unless they wanna play HL2. If you want an SLI card then your only option is the 6600GT in the "bargain" area.
Why? An x300 can't make use of that much ram... it just doesn't have the pixel pushing power. Like my friend's FX5200/128 except even more so.
well afaik the pretty much make them with 256mb ram soo n00bs buy them thinking they are good as they have double than some the others also most n00bs dont realy loook as what series or anything if they saw a 6800gt with 128mb ram and a 9600 with 256mb of ram at the same price they would go for the 9600 straight offf people pay near double for the unused and slower ram at the low end gfx cards
Because it's got more local memory, thus will be faster. When you are sharing a lot of system memory, the more local memory there is, the better, in most cases. There's a difference between 128MB of local frame buffer and 128MB of shared frame buffer IMHO.
also bigz was talking about the 6200TC, any how, we ended getting the x300se as the were out of the 6200TC's now to stress this card
