Modding Cheap Plexi?
Discussion in 'Modding' started by DeX, 2 Nov 2002.
  1. DeX
    DeX Mube Codder
    22 Jul 2002
    Where can I get cheap plexi in the UK for a custom window? I'd like it pretty thin so as I can glue it without the need for moulding. I read this article which says I can get plexi from Homebase but I couldn't find it anywhere on their useless site. :grr:
    Otherwise if anyone's got any spare lying around I only need something 30x40cm or so :D.
  2. SiMonTiST
    SiMonTiST Minimodder
    14 May 2002
    well ,i've got some spare... about 100x50cm. It's clear and 3mm thick, but it's a wee bit scratched, but that'll be easily fixed.
  3. DeX
    DeX Mube Codder
    22 Jul 2002
    Would you be willing to part with it? I'm not sure how you fit something like that through the letter box.
  4. Milk Kid
    Milk Kid What's a Dremel?
    30 Oct 2002
    brut force :naughty:
  5. iSteve
    iSteve What's a Dremel?
    3 Jan 2002
    30x40 ? I can get plexi cheap... this should be like 10 USD ... ... ... and another 10 for shipping, I am afraid :)
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Your best bet would be a local hardware store found on most high streets.
    For 2' x 2' piece you shoud pay about £5.
  7. DeX
    DeX Mube Codder
    22 Jul 2002
    Hmm possibly. Might be hard where I live (only two hardware stores in the whole area and they are tiny). Is the full name plexiglas? If they don't have that should I ask for acrylic or what else is there?
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Only one small hardware store where I live, they called it interior perspex (2mm thick)
  9. DeX
    DeX Mube Codder
    22 Jul 2002
    I think I'll just ask for plastic sheets and see what they come up with. Thanks for the offers by the way guys I realy appreciate it but I rather see what I can find than nicking off other people :).
  10. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Go to a sign shop, that's where I got the plexi for my case badge light, I asked for one 1x1" piece and they gave me about 100, free too :D
    So if you ask nicely you might get some offcuts for free.
  11. DeX
    DeX Mube Codder
    22 Jul 2002
    Cool there is a sign shop the other side of town too. I might check it out.
  12. purple
    purple Minimodder
    10 Mar 2002
    got some from b&q today...
    4mm 4foot by 2 foot... cost£20
    so its there... but i'm sure that it can be found cheaper... i just wanted some NOW....
