Electronics Cheap Quality LEDs
Discussion in 'Modding' started by agray1, 7 Feb 2005.
  1. agray1
    agray1 What's a Dremel?
    12 Jan 2005
    Anyone know a good supplier of cheap good quality Blue LEDS. Looking at getting around 200 to 400 for a future project. Anyone got any ideas where to look?
    Thanks for any help.
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i too would like to know, except id only need 50 or so :)
    frozen cpu has em
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
  4. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    www.lsdiodes.com for all LEDs - ship to anywhere for cheap, huge selection.
  5. coorz
    coorz Miffed
    25 Apr 2003
    Chi-wing on e-bay, could also be the same as that besthongkong shop.
  6. Springs
    Springs Boing boing
    29 Aug 2004
  7. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    I wouldn't use the LED's off Chi-Wing for anything important. The greens and blues have a high tendancy to fail, usually with an almost 0 ohm resistance.
    They're cheap for a reason. If you can put up with the poor manufacturing (I had half a pack of 100 with the flat edge on the anode (longest lead) :eyebrow:, the rest were normal), then go for it.
  9. coorz
    coorz Miffed
    25 Apr 2003
    No kidding :hehe:
  10. SteveyG
    23 Nov 2002
    They're still a good bargain though. Especially if you need lots and lots of LED's.
    The red, orange, amber, white and UV LED's are great - never had a problem with any of those colours. It depends on your application.
    Chi-wing have always delivered within a week of paying without fault.
  11. Kerri Ann
    Kerri Ann What's a Dremel?
    12 Oct 2004
    wow, while ggogling trying to find some prices on leds, i found a site which contains a crapload of info on leds.
    http://members.misty.com/don/ledx.html
    it contains a page which lists some suppliers, but i don't think it's been updated in awhile...
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    LSdiodes.com all the way, fast and cheap shipping from the states :)
  13. agray1
    12 Jan 2005
  14. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  15. SteveyG
    23 Nov 2002
    The red Ultrabright LEDs from Rapid are the best quality I've used, and at a reasonable cost if you buy in volume.
    Shame the pure green LEDs on there are 70p each.
    The 70-99p blue LEDs are very nice from there too, especially part numbers 55-1485, 55-1482 and 55-1480. They're quite a distinctive blue colour.
  16. Kerri Ann
    12 Oct 2004
  17. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
  18. TMM
    TMM Modder
    12 Jan 2004
  19. Kerri Ann
    12 Oct 2004
  20. roll1
    roll1 What's a Dremel?
    21 Sep 2004
    agray1
    Must have missed something cause I can't see why you are saying that besthongkong produce "cheaper/poorer quality LED,s". Only used a few from them and they seemed ok to me.
