Other Cheap Sat Nav
Discussion in 'Hardware' started by MarkW7, 8 Jul 2012.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Does anyone have any recommendations for a cheapish Sat Nav for use on a motorbike, motorbike specific satnavs seem a lot more expensive and not much different.
    It will be wired in at some point so battery isn't really an issue. Not 100% sure what I'm after, pretty sure they're all similar? :thumb:
  2. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    have to get a motorbike version and even then it must be behind the middle of the windshield otherwise water is forced in at higher speeds. You pay more for the high level of sealing and durability required for motorbikes. There is no cheap solution sorry. the cheaper ones break down all the time have a read on motorbike forums.
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I think I'll be going for a car version and fitting inside a waterproofed see through case if needs be. Hopefully I won't have to use it in the rain.
