Guide Cheap sleeving!
Discussion in 'Modding' started by Rufus-Seal, 20 Mar 2005.
  1. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    can someone explain to me HOW THIS IS CHEAPER ???
    really you can get a full molex kit which has like 30 feet of material for like 8 bucks. Or you can buy sleeving for like 30 cents a a foot
  2. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    Duct tape works.... that's really the cheapest thing
  3. Rufus-Seal
    Rufus-Seal Guest
    Well, with the sleeving kit, you MUST take out the molex etc. I don't think that is safe, so i didn't do that. And it takes more time than this. And this is just cheaper...
    @dubya01, and one of the ugliest sleeving :hehe: ..
  4. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    I love duct tape sleeving. I used it to round my ide's in a case without a window to help with the airflow.
  5. Speed
    Speed I'm all you need!
    13 May 2004
    Yeah, duct tape works well. I guess sometimes the simplest changes are the best.
  6. MrMan
    MrMan What's a Dremel?
    5 Jun 2005
    it may not be the cheapest, its just the simplest really. i was thinking of trying duct tape i was just worried when you take it off the wires will be sticky...
  7. Speed
    13 May 2004
    Yeah that could be a problem, maybe wrap the cables in something first. Could be tricky however.
  8. Infraggable Krunk
    7 Mar 2004
    wow your circular reasoning is impressive
    Look it looksd decent, but if you have the time regular sleeving is the cheapest way to go.
  9. nookie
    nookie What's a Dremel?
    28 Mar 2005
    Once I tried this kind o of sleeving but the tube was really unfelxible. It stood like a wooden stick and I removed it. It was looking good but it stood only in straight line ;)
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    that's called split loom nook
  11. B3CK
    B3CK Minimodder
    14 Jun 2004
    Priced some flex tube at the local hardware store, ACE/Westlakes/Lowes/Home Depot, and they all had a wall of spools that ranged in sizes, thickness and ran from $0.10 to $2.25 a ft. length. None of them specified UV reactiveness, but I borrowed a Black light from a few isles over, and 2-3 of them did react, like a transluecent blue.
  12. THEkorean
    THEkorean 42
    10 Jun 2005
    lol man i did that too a while ago, but i took it one step further, i found my dad's old tenis racket grip that was like meshy, so i wraped it around the wires before i put on the tubing lol ALL my stuff was found in the garage lolol
  13. Firehed
    15 Feb 2004
    But of course there are. I was hoping I could make it look identical to my actual water tubes. Chances are that if I cut off the metal ends and recrimped after shoving the wire through I could have just done it, but some three-over-three sleeving covered it just as well.
  14. zmodder
    zmodder What's a Dremel?
    14 Jul 2005
    i would much rather use somethin thats more bendable tho.
