Modding Cheap VFD's & Blue Filters - Where?
Discussion in 'Modding' started by GreatOldOne, 13 Feb 2002.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    I've heard you can get LCD compatible VFD's. I know Farnell do them, but can you get them cheaper elsewhere? I'd be after a 2x20, to fit the cutout I've already got in my drive bay
    Depending on how much they are, I may abandon the idea of blue backlighting my LCD with EL Sheet. I'm thinking it would look better in the Lian.
  2. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    I know you know about farnell, but here is an article that take syou through it.
    Enjoy
    Charlie
  3. Cheese
    Cheese Doc
    6 Oct 2001
    cheaper than farnell? I'd like to see it... :D
    r.
  4. GreatOldOne
    29 Jan 2002
    Fair enough. I'll just have to get one from Farnell. Do they do the filters as well, Cheese?
  5. GreatOldOne
    29 Jan 2002
    Hey!! I'm not mini any more!! :D
  6. Cheese
    Cheese Doc
    6 Oct 2001
    tbh is you're not using a filter because you want to view the display is sunlight then you can use any old coloured plastic - though they do do some filters, yes. Give em a ring and ask for a catalogue.
    Cheers,
    r.
  7. Phrozenpenguin
    11 Dec 2001
    LOl - A catalouge - u'l get about 6 different books, all huuuge, and they weigh a ton:rolleyes: - but bet you can find summat you want.
    Charlie
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Yeah it's not small, but it's free and very easy to browse - lcd's are convenietly next to their huuuge array of leds :D
    r.
  9. Phrozenpenguin
    11 Dec 2001
    I think you can also get it on cd-rom - not so good to browse but easier to search
    Charlie
  10. Cheese
    Cheese Doc
    6 Oct 2001
    But the paper version is soo cool :D
    Cheers,
    r.
  11. Alaric
    Alaric code assassin
    3 Nov 2001
    plus electronics catalogues keep the boilers running thru the winter ;)
  12. GreatOldOne
    29 Jan 2002
    If I got a VFD from farnell, could I stick the backpack on it that came with the milford?
    Sounds a stupid idea I know (in light of Cheese's opinion of it), but Mat-d-Rat has just got LCDC working with it - Top software that I'd be loath to get rid off.
    Would be a straight swap?
  13. Cheese
    Cheese Doc
    6 Oct 2001
    yeah don't wire pin 3 and the backlight pins (15 and 16) but should be fine.
    r.
  14. GreatOldOne
    29 Jan 2002
    Ta!
    time to order, then... :D
  15. GreatOldOne
    29 Jan 2002
    The die is cast... :D
    Just ordered a 2X20 VFD from Farnell. Should be here tommorow.
    Will post piccies once I've installed it - hopfully with LCDC Running on it!!
  16. GreatOldOne
    29 Jan 2002
    Hurrah!!! Postie just delivered... :D
    Booo!!! Had to go to work. :(
    Farnell sure now how to pack stuff :eek: - Large outer box with airbags, Smaller inner box, Anti Stat Bag, Bubblewrap and finally a small plastic bag!!
    Got to find some plastic for filters now - any suggestions?
  17. Cheese
    Cheese Doc
    6 Oct 2001
    You can buy thin sheets of coloured plastic from art shops....
    r.
  18. GreatOldOne
    29 Jan 2002
    Right - got some dark blue gel sheet today, so I'm ready to do the surgery.
    Will report back on the status of my vict... patient later, with all the gory piccies.
    TTFN
    AF
  19. GreatOldOne
    29 Jan 2002
    Unfortunatly, the patient died on the operating table...
    So now I'm waiting for a replacement from Farnell. :(
    Once it arrives, I'm going to cut my losses and wire as parallel (Which means I can't use LCDC! Noooooowwww!!!) and send the carfully embalmed remains to CheeseMan to work his dark satanic arts on them in the hopes of bringing them back.
    Watch this space...
  20. GreatOldOne
    29 Jan 2002
    Replacement VFD arrived this morning - Here we go again... ;)
