HTPC Cheapest intel processor for 1080p playback
Discussion in 'Hardware' started by Kode, 25 Feb 2009.
  1. azrael-
    azrael- I'm special...
    18 May 2008
    Then what do you stand to gain from offloading to the GPU?
  2. Guest-16
    Guest-16 Guest
    I was talking 1080p on CPU only - CoreAVC is highly threaded so even the low clock will work on the 65W Phenom X4s. In some cases the 4850e wont handle 1080p on CPU only - it depends on the material being played and the player.
  3. Kode
    Kode What's a Dremel?
    27 Jan 2008
    Lower cpu utilisation, which i would imagine would lead to lower heat and possibly less power usuage
  4. Kode
    27 Jan 2008
    really? ive not found any cases where the 4850e cant handle it yet, although to be fair i generally only go for 15GB material and less
  5. Guest-16
    Guest-16 Guest
    Well Ive got an 8GB DTS 6.1 x.264 1080p mkv that chugs w/o GPU accel on a 4850e.
    Everything else works perfectly fine.
  6. azrael-
    18 May 2008
    Are you sure it uses the correct codec for video? As far as I recall there're some differences between H.264 and x.264. Also, did you try throwing DivX 7 at it? I have to admit I'm pretty wowed by the performance I've seen so far.
  7. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Probably not, but it will handle sound and video better and with less lag than the E5200
