Displays Cheapest way to achieve 2560 x 1600
Discussion in 'Hardware' started by longweight, 3 Jul 2013.
  1. longweight
    7 May 2011
    Hi all,
    I currently run two monitors at work, both 1920 x 1080 Samsung panels with one in landscape and one in portrait. I am really starting to find 16:9 a pain so I would like to upgrade to 16:10, preferably at the highest resolution possible.
    My work is not colour critical and I am looking to upgrade without spending too much money.
    What are my options? I will likely keep one 1920 x 1080 monitor for the time being.
    Thanks
    long
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Get four 640x400 monitors.
  3. KidMod-Southpaw
    28 Sep 2010
    Ha! I think your best (cheapest) bet would be one of those Korean panels on Ebay.
  4. longweight
    7 May 2011
    What was the name of the manufacturer again? I can't remember!
  5. rollo
    rollo Modder
    16 May 2008
    What he said ebay the resolution you will get a list of monitors for Under £100
  6. longweight
    7 May 2011
    Absolutely nothing that works anywhere near that price.
  7. GeorgeStorm
    16 Dec 2008
    There is no 'cheap' way to get that kind of resolution on a single screen, even if you do buy Korean monitors. (that I know of at least)
  8. GeorgeK
    18 Sep 2010
    Just a thought but if you're upgrading from a smallish monitor (23" perhaps - you didn't say) to a 2560 27"+ monitor would you really notice the extra 160 pixels across the bottom of the screen? I should have thought that 1440p monitors were a good amount cheaper than 1600p ones...
  9. longweight
    7 May 2011
    It's true but I don't think that they are cheap enough for me to go for 16:9.
  10. GeorgeK
    18 Sep 2010
    Fair enough. What, may I ask, is your ideal budget?
  11. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Was it Catleap? Seem to remember some people bigging up their Korean monitors recently and this name springs (pardon the pun) to mind...
  12. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    For something like 2560 x 1440, cheaper is one of those korean ebay ones. There's nothing wrong with them. They're B class panels that were rejected for almost no reason. Normally they're rejected Apple panels. Qnix, Achieva or Yamakasi are the best ones on ebay. They sell for about £200-£250, a little more if you get a pixel perfect one.
    They normally feature a great display with very basic, generic cases.
  13. longweight
    7 May 2011
    It was Catleap but they only do 16:9, looks like Dell might be my only real option.
  14. GeorgeStorm
    16 Dec 2008
    There are Korean companies which do 16:10 monitors.
    Just ebay 2560x1600 and you should get a variety.
    Otherwise you could look at Hazro, I know they certainly used to do a 30" model.
  15. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
  16. Parge
    16 Jul 2010
    Yeah, dude, this is the cheapest option by far. There is a Crossover 30" here for £355.
  17. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    Yamakasi Leonidas 30"
  18. longweight
    7 May 2011
    Budget is around £400.
  19. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Again, no idea on your budget, but DGM is bringing out a new 30" monitor on the same LG IPS panel as the 3011 et al. It'll be LED backlit unfortunately, but it'll still be pretty nice. I would expect it to be in the region of £500, given their equivalent 27" (1440p) was between £300 and £400 depending on sales.
    TFT Central
    Digimate
    Could be worth waiting as it might mean a UK-based seller, which would make warranty a bit easier.
    Edit: Prior reply wasn't there when I posted! Honest!
    Edit 2: Just done some digging. £900. Rats. Korean monitors are your best bet.
  20. GeorgeK
    18 Sep 2010
