Cooling Cheapo Tualatin Watercooling
Discussion in 'Hardware' started by Risky, 1 Aug 2002.
  1. Risky
    Risky Modder
    10 Sep 2001
    I'd like to watercool my Celeron 1.2 as I don't fancy making the cooling too noisy to get it stable over 1.55GHz.
    As most of the watercooling is geared towards Athlons and P4s that will be chucking out several times more heat than this little fellow, I suspect that a lot of the kit about is going to be fairly overspec.
    Does anyone have and pointers where I can look for cheapish waterblocks and suggestions for a suitable radiator. I'm monitoring the FS boards but haven't seen too much yet.
  2. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Well if your on a budget maybe a HWlabs blaze would be good? http://becooling.safeshopper.com/6/142.htm?716 Its $30 bucks, and match that with a heatercore and maybe a via aqua 1300 pump (although i don't like them, but you can do the research on them). Hoses & clamps/water wetter/distilled water and your price is about $100 bucks for the whole setup. Should be good enough for your setup i think. Now if your going for the good stuff then add about $75 to that.
