I found this laser cut grill at pcxmods.com . It kicks butt!! It goes so well with mohaa... This one is a 120mm on top of my lian li. I think I am going to get 2 more for the front 80mms. I like this one much better than the atomic or bio that EVERYONE and their dog has.
Its a 4 leafed clover/shamrock type thing, but god it looks like the Staffe (I think thats what they called it) which the Nazis planted on the wings of their fightters in WW2........ I prefer the hurricane ones myself
hey mugsy, if you got a piece of that carbon fiber vinyl sheet and cut a circle to put over that sticker on the fan, it would look much nicer. specially since its mounted so close to the front bezel. i bought some from www.stickercastle.com and it matches the bezel top very well. if you dont wanna order a whole piece lemme know and ill send ya enuff to do the fan.
center fan cover Hmm nobody likes the iron cross huh? Well I like it and its my case! WWII is over - the nazis lost. Here is some history of the swastica. I didnt write it and its broken english but it does get the point across. Dont let the media tell you what to think. Just because someone took something and tried to make it mean another thing doest mean its bad for everyone. As for the center of the fan I think I am just going to put a piece of black vinyl over it. Your right though it does need something.
Not sure if you are aware of wha carbon fiber looks like, but it matches the top of your bezel there, thats why i suggested it, they have a small pic of it here: http://www.stickercastle.com/film.htm Not sure if it would mater much coz the fan would be spinning 8)
why? I have the same case and you wont be seeing much of the front fans unless you either cut blowholes for leave the front off.
carbon fiber Hey unloaded, I will take you up on that carbon fiber piece. I was looking at it again and the side that is facing up doesnt move so yes the carbon fiber would look pretty good. It is a 120mm fan so just enough to do it would be cool! Thanks As far as the front fans go - Yes I know I would have to fut blowholes. I had thought about doing the extruded plexi tube mod to the front two fans and get rid of that filter that is there. Why would I want to leave the beautiful front bezel off for any reason?!? One more thing that pcxmods has is a fan hole cutting template. You can use this to measure out holes. I dld and printed it and it is pretty accurate.
mugsy drop me a line with your info unl0aded@yahoo.com also how big is that sticker? i dont have any 120mm fans.
That's not a swastika, that is a Maltese cross, the nazis just used it as the shape for the iron cross because they like it's shape
Im gonna have to get some of these Shame they cost so much :cries: anyone know where u can get em in the UK ?
Could you get any more 'greasy trucker' that that grill, looks cool though, just need some chrome exhausts up the side of the case and a cb radio mounted in the front.
anyone know of anywhere doing custom ones, IE I supply a picture? UK a preference, but not essential.
