Check this out: IE Winamp Bar
Discussion in 'General' started by relix, 23 Dec 2001.
  1. relix
    relix Minimodder
    14 Nov 2001
    Home made! Say what you think (on first sight ;) ):
    for the ones who want to try it:
    WinampBar.dll
    Description: an internet explorer bar which has the ability to control winamp.
    Use: register the dll by doing the following:
    1) Copy the dll into windows/system
    2) Start -> Execute with : C:\windows\system\regsvr32.exe c:\windows\system\WinampBar.dll
    3) Open Internet Explorer, go to View -> Explorer Bars -> Dave Studios Winamp Bar
    if you don't understand anything of this you better wait till the first real release with an installer.
    Okay, so if you click in the list on a song title, winamp will start playing that song. If you slide the slider the position will change too (duh), and the other buttons are self explaining (I hope).
    if you've changed the list in winamp, and you want to update the list of the IE plugin, you need to press R while the focus is on the list, so first you select a song, then press r, and the list will update.
    Next release will include a smaller version that can be placed in the toolbar, so it doesn't eat up that much of space.
    Hope you guys like it and give comments, pelease ;p
    Greetz, re|ix
  2. moose
    moose What's a Dremel?
    12 Mar 2001
    First Impression.. cool!
    I might give that a play over the holiday season.. but I'm quite partial to my winamp window as it stands..
    Nice piece of work though! :D
  3. brutal
    brutal What's a Dremel?
    7 Nov 2001
    i have something like that for mIRC. seems like a nice addon for me as the less windows there are the better :)
  4. six degrees
    six degrees What's a Dremel?
    13 Oct 2001
    looks pretty sexy to me :D
    just getting the dll, looks v. useful.
    Well done m8!!
  5. ChriX
    ChriX ^
    30 Aug 2001
    LOL, does that mean its a load of rollocks?? ;):D
  6. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    couldnt get it to work in win xp :(
    i tried c:\windows\system32\regsvr32.exe but it still did'nt work
  7. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    I like the idea m8, needs a bit of sprucing up though to drag me away from using me LCD and minimised main window ........
    Keep up the good work :D:D
  8. vivid
    vivid down in fraggle rock
    24 Sep 2001
    i couldnt get it to work in win xp either, i couldn't even find the file to run it :(
  9. relix
    relix Minimodder
    14 Nov 2001
    thanks for the replies mates!
    about the xp problem: I'm searching the web right now for the problem (need to find a solution on how to register the dll). If meanwhile someone else finds a solution, please post it here!
  10. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    LOL, ;)
    You peeps should be using WWWinamp...
  11. relix
    relix Minimodder
    14 Nov 2001
    WWWinamp?
  12. MrBadidea
    10 Nov 2001
    Its a web-based winamp control thing - 'tis perfect for LAN parties...
    I think its over at www.nullsoft.com
  13. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    odd for u XP people, worked for me using c:\windows\system32\regsvr32.exe c:\windows\system\winampbar.dll
