Cooling cheep wc hd cooler
Discussion in 'Hardware' started by slaw, 12 Jul 2005.
  1. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
  2. Nexxo
    23 Oct 2001
    It's also a bit crappy. The plastic top (and particular those barbs) look rather fragile, and I doubt it can be used on anything but a proprietary Coolermaster Aquagate setup.
  3. slaw
    13 Feb 2003
    i think you are right. i dodnt notice the fixed barbs when i first looked. silly idea by coolermaster
  4. Darv
    Darv Bling!!
    12 Aug 2002
    You can get ones that are a block on either side of the HDD and they connect together at the end. Should be cheaper than a full Aquadrive or similar.
  5. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    how about This
    I believe you can even cool 2 HDs at once with the one set of blocks too :thumb:
  6. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    Or the 3.5" backpack version, only problems are they're not cheap. Maybe the Koolance backpack HDD cooler with the 'koolpack' baggy thing (hrmm), those look cheap, but I would be afraid of the baggy popping :confused:
  7. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    They are cheap. The bag itself is pretty sturdy, but they often leak around the fittings.
  8. fivecheebs
    19 Feb 2003
    I have a severe, and irrational dislike of 3.5" backpack HD blocks, especially if they involve a bag!
  9. kbn
    kbn What's a Dremel?
    17 Mar 2004
    Get some 15mm copper pipe, 2x copper elbows, and some 2mm thick copper bar (2x6" long - two sides, 1" wide * number of drives)
    Drill 6x 3mm holes in the bar, lining up with the ones on the drive.
    solder the pipe to the elbows, then also the bar.
  10. fyes
    fyes What's a Dremel?
    25 Mar 2005
    That's no fun! :D Go for this instead:
    http://forums.bit-tech.net/showpost.php?p=1015831&postcount=94
  11. Firehed
    15 Feb 2004
    Hmm... that one's actually a good idea, but I don't see any screwholes to mount it into the case. I may have to try that though.... I just need a massive slab of copper and about 25093 hours to cut it.
  12. fyes
    25 Mar 2005
    Yeah, I haven't decided how I'm going to mount it in the case yet. As it's rather heavy, I'll probably find a way to attach it to the bottom of the case. Even so, I'd still like to make a quick release system.
  13. kbn
    17 Mar 2004
    With mine, I put some bubblewrap/foam on top of my dvd drive, and sat it ontop. Doesnt look great but it works very well.
