Chemical Warfare
Discussion in 'Project Logs' started by KodiakStar, 3 Jan 2005.
  1. KodiakStar
    KodiakStar What's a Dremel?
    3 Jan 2005
    Hmm. I guess my post died :( not good enough to generate comments between
    real life commitments! oh well mini update time.. its been too damn cold to try and
    do any painting, and having a woman around the apt makes it hard to use loud
    manly powertools.. drat the luck.. but i will be off on thursday and have time to
    do some real modding work...
    Off ebay i got 2 of these CoolerMaster CoolDrive2 HDD 5 1/4 bay hdd cooler/silencer
    according to all the reviews the fans are great and not as noisy as OTHER 40's
    however. I know now why they were being sold on ebay. they are loud. even if I was
    not a modder.. i would still hate them. besides which the front looks stupid on them..
    thankfully the bay covers work around and over them, so I will have to decide on
    a look for them to allow air into the (currently) noisy fan... which will later on be
    taken down to 5v, not as much air will get pushed, but more then there was...
    and it *should* be much quieter... Plus this frees up the 3 1/2 bay so i removed
    that so there is more *space* on the inside of the case for glowy things hinted
    at before...
    When I first did some of the wiring...
    Later on after I wired all the UV LED's and the nice electrical fire..
  2. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    What the f*ck is that... what did you do to those poor wires... :hehe:
  3. KodiakStar
    3 Jan 2005
    its some cheap ass radio shack wire... all the numbers were set for the
    voltage i was running it through etc, tested it out on other stuff, was ok... so went for broke and started smokin and flamin... about 1 second of fun before
    i hit the power ;)
  4. Raymus
    Raymus What's a Dremel?
    29 Jun 2004
    Nice creative paint job. May those destroyed wires R.I.P
  5. KodiakStar
    3 Jan 2005
    Ok. so no posts for a long time. real life sucks! :p
    all joking aside, one of the main reasons I havent done work lately is trying to figure
    out these drive covers for the CoolDrives
    There is the fan that needs airflow, and I am trying to think of some type of cut i can
    do to keep it looking both "stealthed" and fit the theme of the mod :confused:
    just dont know what yet. any ideas? talk to me people!
  6. -EVRE-
    -EVRE- What's a Dremel?
    12 May 2004
    Scrap that ugly plastic front, grab the original alum drive bay cover, and do what you want for air intake, possibly add your own 40mm fans.
    Nice painting skills. I have looked at getting that case off of newegg.com, its a great deal for an aL case with removable MB tray.
    Cool Mod!!!!
  7. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    nice paint job on the camo. just dont like this black/yellow stuff oin the front. damn wire fire :D always remember buy the good stuff for your baby its worth it. anyway keep on modding and update us :dremel:
  8. [Tom]
    [Tom] Minimodder
    10 Dec 2003
    As antiHero says, the front doesn't really work with the rest of the case- the camo looks great though! Maybe continue that kind of thing on the front panel?
  9. KodiakStar
    3 Jan 2005
    Well I am planning on using the blanks that came with the case for the 5 1/4
    bays (x2) for the CoolDrive. I am thinking that I will sand down/repaint the front bez to match the rest of the case, however I need to think of a design
    to dremel into the blank for intake for the 40mm fans attached to the CoolDrive 2's
    __________
    slash vents.. or several lines through the cover
    _____________________
    The 40mm fan is centered in the bay, the middle 2 bays of the 4 I have the
    hdd's in, the top and bottom will be stealthed CDRW/DVD and a plain CD-rom
    just to have things look even
    so
    _______________
    | CDRW/DVD |
    | CoolDrive 2 |
    | CoolDrive 2 |
    | CD-Rom |
    (didnt feel like messing with M$ Paint)
    Also had a suggestion to just do a cut out in front of the fan and just use
    modders mesh (a little over used though) hmm..
  10. antiHero
    19 Jan 2005
    like this one more.
    __________
    its not so straight forward as the other. keep on modding :dremel:
  11. KodiakStar
    3 Jan 2005
    Ok no pics. but what I have done
    Wired up my belgin switch (no led though looks better w/o)
    working on redo'ing the LED's in the fans... (doh!)
    Fixed the second white CCFL to illuminate the ChemW Chart better
    Trying to aquire some mesh soon to make my new stealthy
    covers for them cooldrive2's
  12. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    This hole mod has some UNBELIEVEBLE PAINTING!!! How can you do this!!
    Your paintings may be the coolest in the hole bit-tech history!!
  13. KodiakStar
    3 Jan 2005
    I am [H]ard at work.. um. yea :cooldude:
    will take the existing bay cover.. dremel out the "white" parts
    two rivets per side holding in the mesh
    most likely mesh will be black with the flo. oj colors for the script like I did
    on the sign for the top of the case
    maybe later on I will wire some of my UV leds (if I have any left) and back light it..
  14. KodiakStar
    3 Jan 2005
    Tell me what you think about :
    (it will be much cleaner and spaced out better when I do it on the
    mesh.. but just an idea....)
    Feedback plz! kthxuvrmch
    Other Feedback request. I have heard alot of bitching about the black/yellow on the front
    the front B will get sanded -> painted Urban Camo (when it warms up) but what about
    the section with the power button/usb and bottom of the case.
    //reminder of what it looks like\\
    Since some have said they dont like it. tell me what should be there instead!
    I challenge you!
    Work with me here people!
  15. KodiakStar
    3 Jan 2005
    //RANT//
    I am tired of seeing computer mods that simply
    1)add holes for watercooling parts.
    2)wire sleeve
    3)paint
    4)done.
    \\RANT\\
  16. antiHero
    19 Jan 2005
    sorry if i have been too harsch. ok u want a task or something
    !?!chalanging!?! damn english. :wallbash: how about puting a crystal lcd in the front and program the biohazard sign in 3D and spinning. how about that? or put a Res with green UV water in the front and let bubbles run tru, like those watertowers u can buy. something like that. :naughty:
  17. KodiakStar
    3 Jan 2005
    Hehe. no water cooling on this rig.
    Spent enough on parts, paints, and tools so far :(
    Just thinking... I already installed the plexi for that big square boring looking window...
    Now im thinking I should do some mod work to the window... maybe doing the Urban cammo look to it and using uv-reactive paints on parts. errr or something more official looking... hmm. more ideas for feedback and comments on!
  18. KodiakStar
    3 Jan 2005
    Hmm. No comments? suggestions? :worried:
  19. Jordash
    Jordash What's a Dremel?
    2 Feb 2005
    I prefer this one, it has a real 'Army' feel to it.
    How about an etch on the window to give it some focus?
    not really sure what you're after.
  20. rowan57
    rowan57 What's a Dremel?
    14 Dec 2004
    Get over it!!
    :wallbash:
    Nice project by the way, i like the way the camo has coem out, very cool :)
