Education Chemistry issues
Discussion in 'General' started by profqwerty, 19 Apr 2007.
  1. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Hi all,
    I'm not sure there's a section for this topic, so i guess here will do!
    I have tio plan a chemistry practical, and am wondering how the "100-volume" labellingsystem works?
    We have to figure out the concentration of 100-Volume H2O2, but no where says what 100-vol actually means...
    Any help greatly appreciated!
    Thanks,
    Profqwerty
  2. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    100vol means it decomposes to make 100times its own volume in gas.
  3. specofdust
    specofdust Banned
    26 Feb 2005
    This isn't my question, but what do you mean "its own volume in gas"? Does that mean that it fills 24 litres at SLC, or that it fills 2400 litres at SLC?
  4. profqwerty
    2 Jan 2006
    So if you have 10cm3 of this 100 vol liquid, it decomposes to form 1000cm3 of gas?
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    100vol means that for every 1cm3 that decomposes, 100cm3 of oxygen is liberated. If you're measuring reaction progress using a gas syringe, it's easier that way. To convert it to a normal concentration, remember that 2H2O2 --> 2H2O + O2, i.e. at an x mol dm-3 concentration, 0.5x moles of oxygen are liberated for every dm3 decomposed. From there, you can use the fact that a mole of gas occupies 24dm3 at room temperature and pressure to work out the concentration.
    Is this an A2 chemistry investigation?
  6. woof82
    18 Jul 2005
    There you go, hitman explained it nicely. And yes, they are talking about the A2 chemistry investigation (OCR).
  7. profqwerty
    2 Jan 2006
    woof, It's a past paper now...
    It's a practice practical planning exercise. We have to fully plan two methods of finding out the conc of H2O2. we're given 100-vol as an example.
    I've done tiration with MnO4(-) and the gas syringe one. hopefully nailed it!
  8. rigers
    rigers What's a Dremel?
    2 Apr 2009
    Chemistry A2 OCR Practicle
    Can anyone possibly help me, I am trying to work out the concentration of hydrogen peroxide using a gas syringe. The hydrogen peroxide is 100-volume; how can I work out the conectration of H202. Any help would be really appreciated.
    Thank you.
  9. Krikkit
    21 Jan 2003
  10. rigers
    2 Apr 2009
    Yes I realis that but do I need to dilute my 100-volume hydrogen peroxide with water or not and will this affet my molar calculations because I am thinking of using MnO2 as a catalyst.
    Thank you very much
