Scratch Build – In Progress Cherry wood case water cooled
Discussion in 'Project Logs' started by Tale Gunner, 26 Feb 2007.
  1. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Beast I will make it worth the wait I promise. LOL
  2. Colossous
    Colossous Minimodder
    28 May 2007
    Looking forward to the updates too duder !! :thumb:
  3. Tale Gunner
    15 Dec 2006
    roger that Colossous. I have had some kind of week here.
  4. Tale Gunner
    15 Dec 2006
    New Toy for Fathers day!
    My wife and family got me a gift certificate from one of my local wood working stores so I purchased a laser alignment for my drill press.
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Very very nice gift, gotta love the lasers, I have never seen a drill press with lasers sooo cool
    P.S. What are you going to do with your old one??? :D :D :D
  6. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    awesome dude:thumb:
  7. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Tale Gunner... You and I got the same thing...
  8. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    I new i had seen that laser somewhere else! :D
    btw nice project, really admiring your work!
  9. Tale Gunner
    15 Dec 2006
    When they first came out I wanted one but that was something that was not a requirement for my work just a luxury. Now that most of my tools are purchased and the opportunity presented itself I just couldn't resist. Where did you get yours? I got mine on sale at Woodcraft.
  10. Tale Gunner
    15 Dec 2006
    Thank you, I'm enjoying it for sure.
  11. Tale Gunner
    15 Dec 2006
    This was a add on to the drill press. Aftermarket item.
  12. Tale Gunner
    15 Dec 2006
    Thanks x06jsp. I love toys and my wife knows it! LOL
  13. Pfaffen
    18 Mar 2007
    So did I. I had to get some dark wood glue, french curves and some walnut stain for my case and saw these. I thought they were a luxury as well, but after spending half a day drilling holes, I realized it was more a useful tool...
    It hasn't eliminated all my errors, but at least my eye sight appreciates it.
  14. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    nice lasers. havent seen an update in a while so i assume you are working on those custom panels. take your time, im sure they will be well worth the wait!
  15. Tale Gunner
    15 Dec 2006
    As soon as the stitches heal I will be working on the custom panels again. A 1" chisel took out my thumb. I haven't been hit by a chisel in 15 years. Hummmmph! O Well, I can work on the rest of the case while I wait.
  16. Tale Gunner
    15 Dec 2006
    Well today I started out working on the drive cage and thought about working on the custom panels. I was using a 1 " chisel when I switched hands and put the sharp thingy in my left hand. Well I paid for that mistake. So after my trip to the emergency room I decided to work on the drive cage again.
    I took a small drill bit to make a hole in the metal flange of the drive cage and a small needle bit to open a hole in the cherry wood. I drove in brass nails to hold the drive cage in place.
    After routing my trim on the router table using the smallest cove bit (in keeping with the rest of the wood trim) I began to trim out the drive cage.
    From the picture you can see a new trim piece on the side of the case. I later sanded that smooth and it looks great. Its to support the hinges on the raised panel door.
    Here you can see a rabbet cut in the side of the case. That is to hold smoked plexiglas panels on both sides.
    You can also see more trim on the side of the drive cage.
    Things are beginning to look up on this log.
    Proper clearance on the buttons so everything is good
    Until the batteries went dead on the camera. As soon as they charge I will have more pictures.... LOL
  17. Tale Gunner
    15 Dec 2006
    Well here is the picture of the front of the unit with the trim in place.
    And here is a picture of the new brace behind the hinges (looked really bad in the earlier pic LOL)
  18. mvagusta
    24 Dec 2006
    ouch! :sigh: hope everything heals back even better than before. trim is looking good.
  19. hu$tla
    hu$tla What's a Dremel?
    19 Jun 2007
    looks very good great work on the wood.
    cant wait to see the result
  20. x06jsp
    2 Apr 2007
    looking good!:thumb:
    ouch!! how deep did the chisel cut?
