Scratch Build – In Progress Cherry wood case water cooled
Discussion in 'Project Logs' started by Tale Gunner, 26 Feb 2007.
  1. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Thank you. It looks better then the other day when I injured my thumb. Must have been the drugs!
  2. Tale Gunner
    15 Dec 2006
    Im just an amature at this but I love the hobby. A bad day making sawdust is better then any good day at work! Thank you.
  3. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    So whats left on this bad boy TG? Looks like its pretty close to completion. Are you planning on doing another one just for Sh%ts and giggles? Because you should :D
  4. Tale Gunner
    15 Dec 2006
    Well since I was having a great day I decided to continue my work. I wanted to attach the case to the water pump housing. I drilled the holes with the case and the pump housing at the same time to get the alignment correct. That meant that I had to test the trim around the case for proper fit prior to drilling.
    And the sides.
    And the front!
    Then I clamped down the case, measured and drilled the holes.
    Then I couldn't find my tool to set the inserts so I used a screw and nut to drive them in. No problems with that.
    Last I attached the two parts with screws.
    Adding some of the cooling components here I looked to see what it was going to look like. I love it!
  5. Tale Gunner
    15 Dec 2006
    Well the trim around the outside top, middle and bottom. Then the bronze plexiglas on the sides, sand and sand and sand and sand and stain. Then theres the custom fan grills yet to come. LOL I am thinking about doing a wood monitor then who knows. Maybe try my hand at some of your designs? Thanks greensabbath..
  6. Tale Gunner
    15 Dec 2006
    I have glued the trim between the drive cages and its looking straight.
    Now I need to paint the motherboard tray black to look the same as power supply.
  7. greensabbath
    19 Apr 2005
    Looking great. Curious though, what are you going to do to the drives to make them match better with the wood?
  8. Tale Gunner
    15 Dec 2006
    Well these are just test drives. The ones to be used are black. I have been entertaining the thoughts of a custom wood bezel but nothing serious yet.
  9. Tale Gunner
    15 Dec 2006
    I have painted the Motherboard tray to match the power supply. I think it looks great.
  10. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    Man this is looking T I G H T!!!
    Hey just a thought ... to keep with the black internal theme you have going why not paint the drive bays black also or is that out of the question ... would look super H O T if ya did .. just means those bays wouldnit stick out like a sore thumb! no pun intended!
    w00t!
  11. Tale Gunner
    15 Dec 2006
    Well its an outstanding suggestion but I think its near impossible unless I mask off the entire case. The trim is locking the drive bays in place. But hey that was a good pun. I will think long and hard how to do this without messing up the case. Thank you.
  12. Guest-23315
    Guest-23315 Guest
    That does indeed look tight!
    Are you going to sleeve the PSU to fit in with the mobo tray and drives?
  13. Tale Gunner
    15 Dec 2006
    Yes to make everything very neat inside. Thank you.
  14. Colossous
    Colossous Minimodder
    28 May 2007
    Its coming together a treat Tale gunner !! :thumb::thumb:
  15. Tale Gunner
    15 Dec 2006
    Thanks Colossous. Last week is behind me and the thumb is healing, meantime I am able to make some progress.
  16. Morphine-Kitty
    Morphine-Kitty Dead account.
    22 Apr 2007
    All the updates are looking awesome, good to hear that thumb is healing up nice. :thumb:
    Just a question, what are the planned specs? Is it going to be a file server/gaming beast/silent workstation? Sorry if this has been answered before, but I'm just wondering. I would personally say go with a silent workstation if you haven't already decieded since it would help it blend in with the cabinets.
  17. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looking awesome as allways:thumb:
  18. Tale Gunner
    15 Dec 2006
    This is kind of a multipurpose system with some power behind it. Since everyone at my house has their own system (so that when they need to do homework, research or surf the net, they can) it will be mostly used by me. Asus M2N32-SLI Deluxe Wireless Edition with AMD 5200,(2) PNY VCG8800XXPB GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP, CORSAIR XMS2 2GB (2 x 1GB) DDR2 800 (PC2 6400), (2) Seagate Barracuda 500GB/250GB 16MB Cache SATA 3.0Gb/s Hard Drive, (2) LITE-ON Black 20X IDE Burner with LightScribe Technology, 1000 watt Enermax PS, 600 watt Ultra V PS, Danger Den copper TDX water block for CPU, Danger Den DD12V-D5 Variable Speed Pump, Black Ice II extreme dual radiator, XSPC 150 ml reservoir, Danger Den Fill port, and a bunch of fans. I havent desided beyond that.
    Thank you Morphine-Kitty.
  19. Tale Gunner
    15 Dec 2006
    Thanks x06jsp. As long as everyone is enjoying it I am going to continue.
  20. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    damn, in pic no.2 from the top of this page, the case looks too good - that pic is the money shot! the trim looks 100% and the black paint goes nicely. the whole thing is going from looking good to f'in hot!
